Bouncing RPM at Idle - JeepForum.com
post #1 of 6 Old 11-29-2012, 09:30 AM Thread Starter
xj-jake
88 XJ when I start it in the morning it'll idle fine but the RPM's will bounce 2-300 rmps. Thinking possibly tps? IAC is clean along with the throttle body just did those last week along with spark plugs. I know I'm due for a cap, rotor and wires. Any thoughts?
99 XJ 6.5" IRO Long Arm on 17" Pro Comp 7086 wheels w 33" Tires
xj-jake is offline
post #2 of 6 Old 11-29-2012, 09:41 AM
jminty
Similar problem with one of my work trucks just the other day. Turned out to be the distributor. Id start there.
jminty is offline
post #3 of 6 Old 11-29-2012, 12:41 PM Thread Starter
xj-jake
any other thoughts?
xj-jake is offline
post #4 of 6 Old 11-29-2012, 01:43 PM
bobthecatkiller
"I know I'm due for a cap, rotor and wires. Any thoughts?"
Do this first then post back if it didn't help.
"****, I might **** around and bring the Jeep back No doors on it, flexin' with the seat back"
bobthecatkiller is offline
post #5 of 6 Old 11-29-2012, 02:59 PM
bigbill888
is ac compressor kicking in and out when it does this? Is heater on defrost?
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #6 of 6 Old 11-30-2012, 02:50 PM
PsychoSMurf
Maybe check your vacuum limes, especially the ones in and out of your intake manifold. That happened to me, one little line came out and affected everything.
PsychoSMurf is offline
