Bolt In High Pinion Dana 44
| Truck-Lite's New LED Headlamp Series | Ruffstuff Axle Simple Swap Kit! | Spartan Lockers FREE SHIPPING Excellent Prices |
#31 | ||
Under Construction
#32 | ||
Excellent write-up! I've got a HP D44 housing, and after seeing this I'm trying to decide whether I am capable of doing it or if maybe I should just go with a Wagoneer LP D44, since all that would really need is brackets and a regear.
#33 | |
Under Construction
#34 |
Best write up i have seen yet! keep up the good work and keep us in formed on any other stuff you do to your rig!!
Recovery Crew Club #1 Night Crew #254 RED JEEP CLUB #545 1999 XJ 4 door 4.0 4.5in lift 33x12.50 more mods will be listed 1996 ZJ All stock currently debating what lift and how much to trim! |
#35 |
nice work looks a lot like mine
#36 |
I thought I included your build thread in my links, but I guess not. I will add it.
![]() As far as the truss and link mounts, Im still up in the air about if it was worth it, or if I was better off making it myself. I think it would have been better to buy the coil buckets, and maybe the lower CA mounts, but build my own truss and upper CA mounts. But then again, that would have been a lot of work, so I guess Im glad I bought the kit and modified it. ![]() |
#37 |
i came across a extra ford dana 44 hp axle. i was gonna give it to a friend of mine, but i saw that it had cast in radius arm mounts. can these be ground off? i wanted to make sure before we took a grinder to it, and ruined the whole thing. if figured this thread would be a great place to get a straight answer. thanks.
[B]put er in 2nd and let er eat! use the gas pedal for a brake boy![/B][COLOR="Red"][/COLOR] |
#38 | ||
Take out the shafts and look/stick your hand inside the tube. If the "cast" section is hollow inside, then it can't be ground off. I'm currently trying to decide whether to get a HP 44 I have retubed, or to just go w/ a waggy LP 44. Check my other threads, someone answered that question better in the one about the High Pinion D44.
#39 | |
Under Construction
Just letting you know, I will be doing a similar build in the near future, but unfortunately I will be using a 79 Bronco 44 with the cast in wedges, I am going to pick it up this week. $100 with 4.10 gears and a unknown limited slip, possibly Warn hubs too, I'll find out soon.
I will be having a semi-local shop re-tube it and think I will be getting Solid Axle 44 inner C's, but for now I will be using the stock Ford knuckles, axle shafts, and brakes for now, and upgrade accordingly at a later date(I'm trying to do this on some what of a budget, short term, not long term) once I figure out what bolt pattern I want to go with, and if I want to upgrade to a 60 rear.
#40 | ||
If you look on the first page, there are a couple pictures showing you what a cast vs welded mount looks like. Quote:
Also, why buy all the stuff twice? You may as well figure out what you want to do now, verse but stuff now, and then 6 months later have to buy and redo all your work. Keep in mind that those knuckles do not allow you to do high steer, and they are most likely old outers that will have to be replaced with new stuff. So if youre going to have to buy new rotors, pads and maybe calipers, you might as well either do it the way I did, or do F250 outers for a 8 lug patter (although, you might have issues with that on your rear axle you currently have). My advise, think about it, and then act. I hate having to redo things, and its cheaper in the long run to do it right the first time. |
#41 | ||
Under Construction
#42 | |
Just thought I would give a little update. I got it all going, although I still have to finish wiring up the ARB, putting in the breather nipple, and attach my limit straps.
"Finished" pics ![]() ![]() ![]() ![]() Due to the backspacing on the new wheels, I lost 2'' of overall width. At this point I am still undecided if I like it or not. ![]() Next up, boatsides edit: Forgot to mention that my old HP30 Yukon 4.88 gears are for sale. $90 shipped.
Boatsides/Hybrid Cage/Tube Dash== Custom Winch Bumper== Bolt in HP44 |
#43 |
Excellent write up, excellent work, and I just cant get over that camera strap!
2000 Jeep Cherokee Classic 1992 M101 CDN2 1/4 Ton Off-road Trailer. 90% Daily Driver 100% Fun! ____=__= l l ,[_____], l---- L -[]lllllll[]- ()_) ()_)--o-)_) |
#44 | ||
So for now it will stay wrapped around the camera.
#45 |
lol...
Great write up all the same, well worth the read even if I never intend on doing this myself.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
