Quantcast Bolt In High Pinion Dana 44 - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Bolt In High Pinion Dana 44
Ruffstuff Axle Simple Swap Kit!Truck-Lite's New LED Headlamp SeriesSpartan Lockers FREE SHIPPING Excellent Prices
Old 04-06-2009, 05:55 PM   #16
92XJCowboy
Originally Posted by Starboard M View Post
Rewelding Cs and diff
Skip forward a couple months to allow for more school, come home, and start working again.
A family friend owns a Tig welder, and he kindly offered to do most of my welding for me.
I had him do the welding in several different steps, and the axle got progressively heavier and heavier as it went along.
First, I had him weld the inner C’s up, both inside and outside and also welded the tubes to the center section.
these welds are definitely not clean enough they need to be redone Immediately. I will let you give that axle to me if you dont want to redo the welds again.
“If it rolls, floats, flies or shoots, runs on gasoline or gunpowder, goes fast or shoots a big bullet and makes lots of noise, thus producing torque and recoil — it’s cool.”
Do you want 6,000 acres of land open to OHV's?
Sign the petition for Northumberland OHV Park
92XJCowboy is offline   Reply With Quote
Old 04-06-2009, 06:43 PM   #17
Sierra Drifter
Great job both on the install and the write up. Congratulations, most people have no idea how much work is involved.
2001 XJ RE 5.5 ED w/T&T Y-link longarm, 37" MTR's, D44/D60, ARB's, Rubicon Tcase, and all the usual junk.
Axle swaps & build thread: http://www.jeepforum.com/forum/f11/rebuilding-front-dana-44-a-397243/
Sierra Drifter is offline   Reply With Quote
Old 04-07-2009, 02:22 AM   #18
Jones
Infowars.com
Jones's Avatar
Would you happen to have a list of all the parts that went into this? Maybe you posted that already and I'm just blind.
What is it about Ron Paul?
Jones is online now   Reply With Quote
Old 04-07-2009, 09:13 AM   #19
BRad704
Nothing to see here...
BRad704's Avatar
He was very descriptive on basically each and every step... reading back through should give you every detail for pretty much every part you need...
Originally Posted by Jungle Recon
*** this quote has been removed by BRad, in order to maintain the level of maturity that is required in an online forum of one's peers.
BRad704 is offline   Reply With Quote
Old 04-07-2009, 06:35 PM   #20
Starboard M
Basic list:
-197-1975 Ford F100 housing
-Yukon 4.88 gears with Yukon master install kit
-ARB air locker
-Riddler diff cover
-Alloy USA inner shafts for a Waggy
-CTM U joints
-Warn outer shafts for a Chevy/Jeep 44
-Spindles out of a 1972-1976 Chevy K10
-Hub assembly out of a 1985 Ford Bronco
-Backing plate and caliper off a 1984 Chevy K10
-Warn Premium locking hubs
-Chevy knuckles
-Parts Mike High Steer arms
-Waggy pitman arm
There are more smaller parts, like ball joints and axle seals, but I didnt think you would need to know those.
edit for other things I forgot:
-T&T truss with all mounting brackets
-3/4'' heim for axle end trackbar
-Johnny Joint for frame side trackbar
Starboard M is offline   Reply With Quote
Old 04-07-2009, 06:45 PM   #21
baxy
THAT is one serious front axle!!!
great work
baxy is offline   Reply With Quote
Old 04-07-2009, 06:49 PM   #22
foggybottombob
I heart bacon and pie
foggybottombob's Avatar
As for parts.
Don't forget all the mounting brackets. This one looks like a very expensive kit.
foggybottombob is offline   Reply With Quote
Old 04-07-2009, 07:36 PM   #23
bmyohn
Youngin'
bmyohn's Avatar
One question, will you build one for me?
(runs off to the JY to find himself a D44!)
2001 Dodge Ram 2500 SLT 4x4
5.9L Cummins Turbo Diesel
"The Tow Rig"
1988 Jeep Comanche
2.5L 4cyl - 4 speed manual
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford 8.8" w/ disc brakes l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l 35" Maxxis Bighorns l 15 x 8 Cragar Black Soft 8s (4" BS) l High Clearance Shock Mounts l 4 - BAJA off road lights l TnT Customs D30 Truss l Hidden Hitch l ARB Front Diff Cover l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l HP D30 l JKS Mini Skids and Sway Bar Brackets l TnT Customs OTK Steering
bmyohn is offline   Reply With Quote
Old 04-07-2009, 09:15 PM   #24
gharris54
This is probably the best write up I have ever read on here!
2000 dubya jay, IRO 3'' and 265/75R16 bighorns, quicker discos, custon spring retainers, custom ford 9'' rear end with the stock wj discs
Dana35 SOLID diff cover and a lock-right locker for a Dana35 for sale
gharris54 is offline   Reply With Quote
Old 04-07-2009, 09:20 PM   #25
Starboard M
Originally Posted by foggybottombob View Post
As for parts.
I edited the post.
The truss and mounts were actually not that expensive. Compared to some of the other parts..... very minimal cost.
Sure, Ill build you one.
Lets see..... $65 per hour x 4 years=$9,110,400
How does that sound? Price reasonable?
Old 04-07-2009, 09:31 PM   #26
bmyohn
Youngin'
bmyohn's Avatar
yeah for sure, let me get out my giant cardboard checks for this one
"The Tow Rig"
1988 Jeep Comanche
Old 04-09-2009, 01:25 AM   #27
RrCoX22
awesome write up... definitely will be coming back to this when the time calls
your in the area too... would love to see you beat on this thing
[FONT="Impact"][SIZE="3"]1997 5.2L [COLOR="Red"]ZJ[/COLOR] [COLOR="DimGray"]Limited[/COLOR][/SIZE][/FONT]
[URL="http://www.norcal4x4forum.com"]Norcal 4x4 Forum[/URL] | [URL="http://www.fquick.com/RrCoX22"]My Garage[/URL]
RrCoX22 is offline   Reply With Quote
Old 04-09-2009, 11:40 AM   #28
foggybottombob
Who is T&T?
Listed as the mfr of the truss.
Old 04-09-2009, 12:00 PM   #29
RockRodHooligan
Under Construction
RockRodHooligan's Avatar
1989 MJ Comanche
Who is T&T?
http://www.gotreks.com/treks_home.asp
Penis inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
I seen a frog once that ate a rolypoly that locked onto it's tongue and I rescued it from starvation by removing the rolypoly.
RockRodHooligan is offline   Reply With Quote
Old 04-09-2009, 12:50 PM   #30
foggybottombob
Originally Posted by hotrod_hooligan View Post
Looks like $150 or so. Most of the other vendors want several hundred for a set of brackets. I went "ghetto" with ballistic fab and it's still going to cost me around $150 even though I got one UCA bracket as a leftover from a shop for $10. I wish I had seen this set about a month ago.
Glock Forum
