Bolt falling out of engine? - Page 2 - JeepForum.com
post #16 of 20 Old 09-06-2010, 10:16 PM
menace2
The "Renix" Fuel Injection System is an older computer system found on Jeeps from 1986 thru 1990. Renix made computers that controlled emission carbuerators used by AMC, Volvo, and Renault (Renault and Bendix started Renix) as well as early Fuel Injection Systems. You'll find the word Renix used to denote these older Jeep Fuel Injection Systems here on Jeep Forum.
Your 1999 Cherokee is an OBDII. It is two (arguable three) generations newer than the Renix. The OBDII systems don't use Exhaust Gas Recirculation (EGR).
EGR is taking some exhaust gas out of the exhaust manifold and feeding into the intake manifold to cool the combustion for emission purposes. Later computers and fuel injection systems no longer needed it to meet the legal emissions requirements.
The older carbeurated and Renix Jeeps had a tube going from the exhaust manifold to the intake manifold to feed the exhaust gas through a valve = EGR. Your 1999 Cherokee did not come with it. Your Dad's friend or the previous owner has put an older, EGR type exhaust manifold on the Cherokee. No biggie if it runs. The late 90s Jeep manifolds are prone to cracking. The Previous Owner (PO) probably got the older manifold cheap and threw it on to replace a cracked one. He had to block or plug the tube for the reason you've discovered. The plug is just a brass plumbing fitting with a bolt and nut down the middle.
A newer, correct, tubing type exhaust manifold is more effecient and will produce more power.
menace2 is offline
post #17 of 20 Old 09-06-2010, 11:03 PM Thread Starter
Steev89
ok cool well thank you very much I really appreciate it. Ill see about geting some money together to get a better exhaust manifold then. Again thank you all very much
Steev89 is offline
post #18 of 20 Old 09-06-2010, 11:27 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Makes you wonder what else the dude cobbled together.
ratmonkey is offline
post #19 of 20 Old 09-06-2010, 11:29 PM
menace2
You can order the newer manifold online for about $100. Less on eBay. The newer version has what looks like accordion flexible tubing on the front and back runners to help prevent the cracking from occurring during the heat/cool cycles.
[IMG][/IMG]
menace2 is offline
post #20 of 20 Old 09-06-2010, 11:39 PM Thread Starter
Steev89
Your right ratmonkey it does make me wonder and hope he didnt do something that will come back to bite me too bad. And thank you again menace, 100$ isnt too bad so I should be able to get that soon hopefully.
Steev89 is offline
bolt , cherokee , engine
93 xj engine/transmission bolt Sykes XJ Cherokee Technical Forum 4 05-31-2010 07:24 PM
Engine Swap...need some bolt sizes and a few ?'s jeepxj2007 XJ Cherokee Technical Forum 1 05-28-2010 01:40 PM
does anybody make an engine bolt kit for the 4.0? BigOrangeXJ XJ Cherokee Technical Forum 9 06-06-2007 09:58 PM
Broken Bolt in engine problem? Gsmyth75 XJ Cherokee Technical Forum 7 05-29-2007 05:56 PM
engine mount bolt? DeathCrush XJ Cherokee Technical Forum 3 10-31-2004 08:18 PM
