Blown head gasket. Is it worth replacing? - JeepForum.com
post #1 of 22 Old 05-02-2011, 09:25 PM Thread Starter
taylorC
1997 XJ Cherokee
I have a 97 jeep Cherokee with a 192000 miles and a blown head gasket. Is it worth it to replace the gasket? Every opinion and angle is welcome! Thanks in advance guys
97 Cherokee sport-4x4/2"BB /Kumho AT's/ Hella 770ff
taylorC is offline
post #2 of 22 Old 05-02-2011, 09:28 PM
94chb
not a hard job to do, i would replace it, if the engine is healthy.
94chb is offline
post #3 of 22 Old 05-02-2011, 09:30 PM
BEETROOT
What will you do with the Jeep if you don't fix the gasket?
BEETROOT is offline
post #4 of 22 Old 05-02-2011, 09:41 PM
ahuf
In short I say fix.
As long as the Jeep is mechanically sound.
ahuf is offline
post #5 of 22 Old 05-02-2011, 10:16 PM
robsjeepxj
I'd pull the pan first and plasti-gage ALL of the rod and crank bearings and look for any visible signs of damage. No use doing anything to it if the bearings are blown. Coolant in the oil will destroy the bearing very quickly so it's better to know for sure than guess and be wrong. If they are bad then a long block can be had for like $1800 or so and you'll be good to go for another 190K. Replacing the oil pump and RMS at that mileage is a smart idea anyway so you'd pretty much have the pan off anyway.
robsjeepxj is offline
post #6 of 22 Old 05-03-2011, 02:52 AM
tjjeepwrench978
1997 XJ Cherokee
I say throw a 20 dollar gasket at.wit air its a 3 hour hit
tjjeepwrench978 is offline
post #7 of 22 Old 05-03-2011, 05:03 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Sampling the bearings is never a bad idea. Especially if the engine has been driven for a while with the blown head gasket.
As far as replacing the gasket, it is inexpensive and not particularly difficult. Consult a factory service manual and read the procedure BEFORE starting if you've never done one before.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #8 of 22 Old 05-03-2011, 05:41 AM
robsjeepxj
I guess since no one has said it yet being that it's a 2001 4.0 you more than likely have cracked head as apposed to just a blown gasket. The gaskets don't really go on these that often but the heads on the other hand are known to definitely crack.
post #9 of 22 Old 05-03-2011, 06:03 AM
tjwalker
tjwalker's Avatar
His XJ is a 1997, not a 2001.
BUT, if you pull any head off, you should take it to a machine shop to have it checked for straightness and cracks before putting it back on. Money well spent.
tjwalker is offline
post #10 of 22 Old 05-03-2011, 06:34 AM
cbordea
on my 98, I found that if the head was cracked, it was cheaper to buy a running/used engine and swap it in than to buy a used head and all the gaskets, head bolts, etc.
88 MJ I6 4x4 Stock my hauler - Sold
98 XJ I6 4X4 Stock my son's DD
06 12V Purple Barbie Jeep my daughter's DD :-)
cbordea is offline
post #11 of 22 Old 05-03-2011, 07:26 AM
justanotherjpr
Do the gasket. Have the head tanked, machined flat and fluxed for cracks. Don't get talked into a valve job unless the valves are totally blown apart.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #12 of 22 Old 05-03-2011, 08:45 AM
4ll4boutda4play
1997 XJ Cherokee
I replaced my cracked head for less than 300.. I pulled the head off of a salvage jeep paid 45.00 for it. took it into a shop and had them check and machine it. local shop charged me all of 50.00 to get that done then I bought a valve spring compressor and pulled the valve seals and old valve out. "donor vehicle indicated 230k" replaced all the valves and springs and retainers along with the seals then "got those for free" Gasket kit cost me 65.00 felpro and then fluids. along with t stat and pump etc ... was a easy job
1997 Cherokee Sport, Rustys Intake with velocity stack and larger cone filter, Flowmaster 40 series, Junkyard Lift 3.5", Zone Nitro Shocks, Trimed fenders, 35x14.5x15 TSL Thornbirds (Looks HUGE) ... trail damage :) Future holds Aftermarket bumpers front and rear, exo cage, lockers/gears
4ll4boutda4play is offline
post #13 of 22 Old 05-03-2011, 11:33 AM
Dead_End
1990 XJ Cherokee
replacing the head gasket really isn't a hard fix. I recommend getting someone to help lift the head in and out of the Jeep, it's heavier than it looks and you don't want to damage it. Otherwise, it's a one person job. It took me about 4 hours to to mine.
[/Kevin]
_____________________________________________
Jurassic Park '90 XJ, '00 TJ
Dead_End is offline
post #14 of 22 Old 05-03-2011, 11:41 AM Thread Starter
taylorC
1997 XJ Cherokee
Thanks for the help so far everyone. I appreciate it. I plan on having some help from two other gear heads when I do this job. I have also been told that if I get the head off there is a way you can tell if it's cracked and or warped. Is this true? Also what are the recommendations/opinions about just replacing the gasket without having the head checked and magnafluxed?
taylorC is offline
post #15 of 22 Old 05-03-2011, 01:59 PM
justanotherjpr
You can check the head for flatness with a ruler and a flashlight.
You can just R&R the head without having it checked but IMO its worth the money to make sure I'm putting on a flat, uncracked head. A gambling man may feel differently.
