Blowing fuses.....why? - JeepForum.com
post #1 of 4 Old 07-14-2005, 11:03 AM Thread Starter
PRYDE
Question Blowing fuses.....why?
Well I thought I had everything electrical sorted out with the jeep, but it turns out not. Earlier I had a problem with my winshield wipers not working, and some weird noise when they were engaged comming from under the dash. I figured out the problem was comming from the fusebox with the small windshield wiper module (I beleive it's called that) having a spark jump between the twopoints on the module. I decided I would touch the two prongs together and not the windshield wipers work flawlessley.
The problem now is that when I turn on the running lights the fuse blows for them. The brake lights wont work or the running lights. I took a look at the fuse and it was a 30 amp in a 10 amp socket ...the original owner must have had some problems too with it.
Does anybody have a clue about what could keep blowing this fuse? The clock goes out for the time the lights do come on (only a short period of time before the fuse goes)
I've been having a ton of electrical problems with the jeep and I'm wondering if it could all be caused from one thing.
Do you think the problem might be because I have bent the windshield wiper module tong things (dont know the name) together permanently?
Hopefully you can help me out....this has been only headaches for me....yikes
'87 XJ...400$ STOCK
Currently stripped down to nothing...
Getting rebuilt slowly but surely...
It's a fixxer upper, but thats part of the fun.
PRYDE is offline
post #2 of 4 Old 07-14-2005, 11:50 AM
laxfeva22
Junior Member
I have an 87 too and i have a wire that is a little on the bare side so when im driving down the highway and the rattle starts (need a re-alignment), it shorts the rear-lights and dash-light's out and blows the fuse. You probably have a wire that simply got worn bare and is in permanent contact with some meatl, causing it to short.
laxfeva22 is offline
post #3 of 4 Old 07-14-2005, 12:30 PM Thread Starter
PRYDE
I was checking all around the jeep at all the wires and I dont know how I missed it before, but this might have something to do with it.
These pictures are taken at the rear left side where the wiring harness comes up from the front.... are they all ground wires?....or wires that the guy had put there to try and solve something??
Cutoff wires...
http://img.photobucket.com/albums/v4...p/cutwires.jpg
Ground?...
http://img.photobucket.com/albums/v4...eep/ground.jpg
Connectors...
http://img.photobucket.com/albums/v4...connector1.jpg
http://img.photobucket.com/albums/v4...connector2.jpg
The mess...
http://img.photobucket.com/albums/v4.../Jeep/slew.jpg
Can ungrounded wires cause fuses to blow?
'87 XJ...400$ STOCK
PRYDE is offline
post #4 of 4 Old 07-14-2005, 12:33 PM
twisted_ed
twisted_ed's Avatar
i had the exact same problem, mine was this: the previous owner had an electric brake tow lights thing installed. they just used the "place the wires in the joiner and push it closed and it would slice partway through both wires." connectors, and garbage way to, anyways after cracking a taillight i assume that water got in there and over the years cause some shorting out. i went in, cut out the tow package, cut and resodered wires together and shrinkwrapped each wire where that connect thing cut through the electric wire sheath and now its fine.
1990 Jeep Cherokee Laredo
4.0L
Automatic Tranny
NP242 Transfer case
Dana 30 front, 35 custom rear differentials
Mods:
RE 4.5" Lift
32x11.50 BFGoodRich M/T KM's
American Eagle 058 Polished Aluminum Wheels, 3.63" BS.
Grand Cherokee Rear Disc Brake setup
Custom Downpipe W/ Cat Removed.
Dynomax Super Turbo Muffler.
Surco Roof Rack
twisted_ed is offline
Blowing fuses curtsjeep XJ Cherokee Technical Forum 3 07-26-2009 08:49 PM
fuses keep blowing..need help mmaverick88 XJ Cherokee Technical Forum 3 06-25-2009 11:00 PM
always blowing fuses in 99 xj please help weegie22 XJ Cherokee Technical Forum 3 06-02-2009 10:30 AM
Blowing Fuses Razor. XJ Cherokee Technical Forum 6 06-21-2006 11:55 AM
blowing fuses Goonowsky XJ Cherokee Technical Forum 1 02-12-2005 04:55 PM
