Blowing fuses - JeepForum.com
post #1 of 3 Old 08-05-2011, 05:44 PM Thread Starter
97whitexj
Blowing fuses
My 97 has developed the curious problem of popping the "Transmission control module, powertrain control module, automatic shutdown relay, fuel pump relay" 20a fuse on the passenger kick panel.
It only does this when I shift down to 1-2. Any ideas?
97whitexj is offline
post #2 of 3 Old 08-05-2011, 06:54 PM
Curly5759
There is most likely a short in the transmission range sensor or in the wiring between it and the transmission module. Looking at the wiring diagram, the fuse that is blowing is common to all those things. Since it only blows in 1-2, the problem lies there. you can try removing the connector from the transmission module and then try moving the shifter with the key on. See if the fuse blows. That will narrow down whether it is the module causing the problem or a short in the wiring.
The trans module is inside behind the center console. Have you added any accessories that might have pinched a wire? BTW, the 1-2 wire is the VIO-WHT wire on the shifter and module.
Curly
I start what I finish!
77 Jeep Cherokee S
97 Jeep Wrangler
Curly5759 is offline
post #3 of 3 Old 08-05-2011, 07:05 PM Thread Starter
97whitexj
I ahve not done any accesories at all that would have pinched a wire.
It does not go immediately after shifting into 1-2 I usually get halfway up the obstacle and it goes.
Blowing fuses? anderson5290 XJ Cherokee Technical Forum 7 01-19-2011 04:32 PM
Blowing fuses curtsjeep XJ Cherokee Technical Forum 3 07-26-2009 07:49 PM
fuses keep blowing..need help mmaverick88 XJ Cherokee Technical Forum 3 06-25-2009 10:00 PM
always blowing fuses in 99 xj please help weegie22 XJ Cherokee Technical Forum 3 06-02-2009 09:30 AM
Blowing Fuses Razor. XJ Cherokee Technical Forum 6 06-21-2006 10:55 AM
