blower motor, radio, backup lights, wipers only work when key on accessories - JeepForum.com
post #1 of 3 Old 04-20-2013, 10:08 PM Thread Starter
natureroad
1995 XJ Cherokee
Strange things going on. Blower motor, radio, wipers, backup lights quit working. replaced 30 amp fuse in panel. Now all of them work when key in accessory position but not with engine running (key in run position). Any ideas. Thanks in advance.
natureroad is offline
post #2 of 3 Old 04-21-2013, 08:24 AM
habbyguy
It sure sounds like the ignition switch. I can't think of anything else (other than a wire or connector associated with the ignition switch) it could be. I'm betting whatever blew the fuse took out the circuit in the switch.
The good news is, they're not too expensive, or too hard to change.
habbyguy is offline
post #3 of 3 Old 04-24-2013, 10:04 PM
Simmbad
1976 CJ7
I had a burnt ignition switch, same issue your having, bought a new one, went to pick and pull for the plug end (mine was melted) fixed that problem, good luck
Simmbad is offline
