Blend doors not working - JeepForum.com
post #1 of 6 Old 08-08-2012, 12:36 PM Thread Starter
spalatucc
1997 XJ Cherokee
I just replaced my heater core, evaporator core and blower motor and before this the air would flow through all my vents fine. Now it seems the blend doors are not opening when I try to turn the air on. I made sure I reattached all the vacuum hoses in their correct positions before putting the HVAC back in as well. Any ideas why as to why it isn't working correctly now?
spalatucc is offline
post #2 of 6 Old 08-08-2012, 05:02 PM
AZ Jeff
2014 JK Wrangler
Since all the doors are vacuum operated, and you say none of them function (the are called "MODE" doors, BTW. The "BLEND" door controls air temperature), I would guess you have no vacuum going to your mode control knob. Check that first.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 6 Old 08-08-2012, 07:15 PM
ThaKmFb
The blend door is actually cable driven. The mode doors are vacuum operated. Make sure you have a black and a gray hose goin through the firewall with the evaporator connections. The black one is the supply to the control head the gray one goes to the heater control valve. Make sure you dont have the switched. If those are o.k. check and make sure you have vacuum at the a/c control head. Then go from there.
ThaKmFb is offline
post #4 of 6 Old 08-10-2012, 04:50 PM Thread Starter
spalatucc
1997 XJ Cherokee
Mode door
Thanks guys for the replies. When I cycle to a different mode the doors don't open, but if I cycled all the way through and on the way back stop at the one I want it opens correctly. I made sure I plugged all the vacuum hoses up correctly (I've made the mistake of not taking pictures and documenting where things go when I rebuilt my engine). Also, I didn't even touch the one on the control knob
post #5 of 6 Old 08-10-2012, 06:17 PM
AZ Jeff
2014 JK Wrangler
That sorta sounds like a control problem. Check the vacuum lines that run from the control panel to the junction block behind the glove compartment on the heater box.
AZ-Jeff
AZ Jeff is offline
post #6 of 6 Old 08-10-2012, 06:28 PM
ThaKmFb
Sounds like maybe the control head
ThaKmFb is offline
a/c , blower motor
1997 xj power window/doors not working dhoge88 XJ Cherokee Technical Forum 7 03-15-2014 08:43 PM
climate control blend doors mustfade1 XJ Cherokee Technical Forum 13 10-28-2010 06:56 AM
Help with HVAC "Blend Doors" kadetklapp XJ Cherokee Technical Forum 34 11-07-2008 06:18 AM
Rear doors not working XJ Blue XJ Cherokee Technical Forum 10 12-01-2007 12:32 PM
Help! Blend doors? Willy D XJ Cherokee Technical Forum 2 03-23-2007 02:07 PM
