Black key wont turn, and locked in park. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Black key wont turn, and locked in park.
The Cure for your Tie Rod Roll!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Boss is away but Erin is here to STAY with a F.Y.S. Sa
Unread 02-16-2014, 10:57 AM   #1
irs009
The title says it all. I went to a Drugstore last night and this was the condition I came back to. I have two black keys and they both do the same. Help please.
Jack
2001 XJ - bump
irs009 is offline   Reply With Quote Quick reply to this message
Unread 02-16-2014, 11:01 AM   #2
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Did you try rotating the steering wheel both ways while turning the key?
Sometimes if the wheels are turned a bit it can put enough pressure against the ignition interlock to keep the key from turning.
***Chris***
JeepForum.com/IndyORV@Redbird-SRA
COTY 2009
chris87xj is offline   Reply With Quote Quick reply to this message
Unread 02-16-2014, 11:22 AM   #3
irs009
Yes I did Chris...Thanks
