Bimetallic Temp Sensor issues - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Bimetallic Temp Sensor issues
Engo LED Flush Mount Lights *PAIR* Flood or Spot 1,600 LumYukon Ultimate 35 axle kit for c/clip axles with Yukon ZipRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits
Unread 10-16-2014, 08:59 PM   #1
bigcnobles
1989 XJ Cherokee
I was recently replacing the flexible air hose from manifold to intake of the Thermostatic Air Cleaner on my '89 Jeep Pioneer, and decided to make sure the cold/hot diverter valve was working. The vacuum motor worked, but when I cranked the vehicle when cold, I noticed the trap door would not close to the cold intake to allow the warm exhaust from the manifold to enter the airbox. Traced back to the bi-metal temp sensor that is attached to the back of the airbox. I dont think it is working; I heated it up and couldnt notice any air flow through it. I dont have a vacuum pump, so what is the best way to check it out? Also, where can I find a new one? Do I need to go to a junkyard to pull one off another old Jeep. I am not sure how long Jeep made this part before they changed it. While I am asking all these questions, some buds tell me its not worth it to fool with it, but I am concerned that it will make for a tuff cold weather commute this winter if I get no advanced warming from the exhaust gases. Does it really make a difference in cold weather?
bigc
bigc
bigcnobles is offline   Reply With Quote Quick reply to this message
Unread 10-17-2014, 06:10 PM   #2
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Your buds are correct.
Originally Posted by chris87xj View Post
If you own a Renix Jeep, you'll want to check this out. >
An index to over 25 write-ups can be found in Post #1.
Cruiser's Mostly Renix Tips
My Jeep Technical Photos
http://www.cherokeeforum.com/g/album/1725214
cruiser54 is offline   Reply With Quote Quick reply to this message
