Quantcast Bilstein shocks cheap - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Bilstein shocks cheap
GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp SeriesRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 11-07-2009, 02:24 PM   #16
blue96jeep
ok by no means am I looking for a cadillac ride, thats impossible, i am just looking for a suspension set up that takes some of the bumps.
-Ryan
blue96jeep is offline   Reply With Quote
Old 11-07-2009, 03:26 PM   #17
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
I'd just get some good quality shocks, then lower the air pressure until you find a happy medium between gas mileage and ride quality. You can lower the pressure to 28 or less and still have a good contact patch with a very minimal if even noticeable change in fuel economy. These two things will help the ride quality, I was just saying don't expect a world of difference even though you dropped 300 or more on a set of shocks.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Old 11-07-2009, 04:15 PM   #18
Luke94XJ
1994 XJ Cherokee
NO NO NO XJfeaver, you meant he was ****ed and will never have a good driving Jeep ever again and it will roll over now and explode and things. J/K He seemed to get worried about his LCAs when you mentioned the angle, but that's just the way lifted jeeps are.
Luke94XJ is offline   Reply With Quote
Old 11-07-2009, 06:41 PM   #19
blue96jeep
not worried about the LCA angle too much unless I should be, I just don't want to add something to my jeep and find out that it would not affect the ride quality what so ever. I don't have money to waste.
if the consensus is that UCA & LCA relocation brackets, new shocks and full leaf packs are the way to go. Then cool.
-Ryan
Old 11-07-2009, 07:39 PM   #20
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
You can't use control arm drop brackets with 3" of lift. They are for 4.5" and up. The shocks and lower tire pressure will help, and that is what I would do. The lower tire pressure will make as much difference as the shocks if you are running 35 psi or more. Try lowering it to 28 and see how it rides. Again mine is at 26psi and I get 14.5 to 15mpg's on 31" tires and stock gears. The contact patch is perfect as measured with the chalk test and the tires wear very even. Jeeps are light weight and don't need that much tire pressure.
Old 11-07-2009, 11:06 PM   #21
blue96jeep
I thought so... then my only options are new shocks and full leaf packs plus airing down tire to 28
Old 11-07-2009, 11:33 PM   #22
RockRodHooligan
Under Construction
RockRodHooligan's Avatar
1989 MJ Comanche
There is another option, and it would get you a great ride, but it's not as cheap: Treks Offroad Products - Y-Link 3.5" Suspension System
Otherwise, yeah. New leafs, shocks, and airing down a little will help the ride a lot.
Penis inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
I seen a frog once that ate a rolypoly that locked onto it's tongue and I rescued it from starvation by removing the rolypoly.
RockRodHooligan is offline   Reply With Quote
Old 11-29-2009, 09:11 PM   #23
Muddeprived
This is what I'm doing. I'm in the same boat. I have a 3" lift and want to improve the ride. Instead of throwing on expensive shocks, I am going to upgrade my arms to a long arm kit so they are as parallel to the ground as possible. That's how you get a better ride.
Old man emu or bilstein shocks WILL help some, but not with OMG!! results.
2001 XJ Sport 4.5" RC LA
Custom snorkel
Detours/winch
Flux Capacitor Heat Machine
Muddeprived is offline   Reply With Quote
Old 11-30-2009, 10:43 AM   #24
blue96jeep
I just got done reading some posts from search and as far a manufacturer to go with is debatable, but the biggest thing is that for a long arm upgrade for a 3" lift is you will lose ground clearance, but I don't think I can put a upgrade that will be lower to the ground.
-Ryan
Old 11-30-2009, 10:55 AM   #25
tangofox007
Driving any vehicle, especially one used primarily as a DD, is really dangerous at moderate to high(interstate) speeds!
Is that really what you meant to say?
tangofox007 is offline   Reply With Quote
Old 11-30-2009, 02:47 PM   #26
blue96jeep
not at all
Old 12-01-2009, 02:13 PM   #27
RockRodHooligan
Under Construction
1989 MJ Comanche
-Ryan
Take another look at TNT's Y-link. With the belly pan, you gain an inch of ground clearance over stock, and the control arms are mounted above the belly pan. Hell this pic is with 5.5" of lift and the control arms are barely causing any clearance issues, 3.5" and it would be nearly invisible.
Lol, good catch.
Penis inches...
Glock Forum
