Billy Mays Magic Putty - JeepForum.com
post #1 of 16 Old 06-19-2008, 01:59 PM Thread Starter
dert
Have some Cherokee factory molding that I have tried anything and everything to hold the peeling off side molding on.Now I have applied upholstery screws to the ends that are peeling off.Anyone tried this putty stuff ?? Thought i would put some of this stuff on and rescrew down and let it cure and remove the screws and patch the molding up and repaint or something where the screw holes were.Any better ideas or is there another product out there besides the worthless 3m auto 2 sided tape made specifically for this type of application?Doesnt look bad now but there has got to be a better way aside from removing the molding all together and or replacing it.
dert is offline
post #2 of 16 Old 06-19-2008, 02:03 PM
chrisja77
Not for sure what all will work, but I don't think I would trust anything ole Billy says. Just my .02!!!
chrisja77 is offline
post #3 of 16 Old 06-19-2008, 02:04 PM Thread Starter
dert
he is kind of" in your face",huh?
dert is offline
post #4 of 16 Old 06-19-2008, 02:15 PM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
He thinks I'm deaf.
Anyways, Ive seen on the commercial him making a chain link out of some and towing a semi with it. But then again youre supposed to believe everything you see on commercials right?
88XJSport is offline
post #5 of 16 Old 06-19-2008, 02:40 PM
Parky
Parky's Avatar
Use 3M 5200 Fast cure. Once it cures, the door will come off before the molding. I used some on my factory rack. No more worries of losing my skis.
Colorado Jeep Member #12
Happy Jeeper
Parky is offline
post #6 of 16 Old 06-19-2008, 02:50 PM
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
I've had extremely good luck using the 3M emblem tape (the double-sided foam stuff). I had to relocate the Cummins badges on our Ram's fenders to fit the Bushwacker flares and they're rock solid with the 3M stuff. Our VentVisors and OEM Mopar door trim pieces (similar to the door molding on late model XJs) are stuck on with basically the exact same stuff.
The magic putty is junk. One of the local new stations here in DFW does what they call "Deal or Dud" where they test lots of these tv products that sound too good to be true. They tested the Magic Putty stuff. Recreated all the things you see in the tv ad. IIRC, the only thing it actually succeeded in doing was fix the leaking drinking glass.
edit: what you probably need to do is completely remove the trim molding in question, clean all the old tape residue off of it and the door -- get both surfaces nice and clean. Then use the 3M emblem tape to reattach the molding.
Jason West -
'16 JKUR Hard Rock, RE/Synergy 3.5", 37" GY MTR/Ks
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline
post #7 of 16 Old 06-19-2008, 06:12 PM
ReconMill
Flat-4 Turbo
ReconMill's Avatar
2005
HI BILLY MAYS HERE! DONT USE MY PRODUCT CAUSE IM FULL OF ****! HOWEVER, ITLL TAKES THE POOP STAINS OUT OF YOUR *** HOLE REALLY GOOD. EAT SOME BACON!
yeah im bored... so what. As for the door molding, i just ripped mine off and left it off. Looks cleaner, but if i ever put it back on definately use 3m double sided like mentioned.
Kyle - I mod stuff®
2005 Subaru Legacy GT
ReconMill is offline
post #8 of 16 Old 06-19-2008, 06:29 PM
sccrstar011
1995 XJ Cherokee
5200 is some great stuff. I would try that before that silly putty.
sccrstar011 is offline
post #9 of 16 Old 06-19-2008, 06:46 PM
winkosmosis
Regular 3M double sided tape held a metal UT Longhorn emblem to my WJ for 2 years.
Atheist Jeep Club member #3
Non-Astrologist Jeep Club member #?
Pull the Socialist Plug on Old People Jeep Club member #1
winkosmosis is offline
post #10 of 16 Old 06-19-2008, 09:37 PM
Cherokeekid88
1997 XJ Cherokee
I actually got some of that magic putty. Its horrible. end of story. When you cut it and kneed it with your fingers, it leaves a horrible smell and it cant hold any pressure. and it doesn't hold up diddly.
97 XJ 4.0 Auto D30/29 Sp. 8.25. Yukon 4.10's
4.5" IRO Long Arm Kit - 33x12.50x15's
HD Offroad Engineering Shackle Relocation Brackets
Bilstein 5100's - Magnaflow Exhaust.
Cherokeekid88 is offline
post #11 of 16 Old 06-20-2008, 05:45 AM Thread Starter
dert
The problem with the door trim is that it is a bit warped and pulled away about an 1/2/" and thats why the 3m tape didnt hold even after I cleaned it off good.Got some of the 3m5200 fast cure and applied and rescrewed the trim back down and heading to Red River,NM sunday and will see how it adheres when I get there and remove the screws.Thanks for the tips..off and running.
dert is offline
post #12 of 16 Old 06-20-2008, 05:48 AM
justinwalden
what a cruel joke. have you tried melting it off?
Tennessee, Tennessee, There ain't no place I'd rather be!
justinwalden is offline
post #13 of 16 Old 06-20-2008, 06:13 AM
Crystalship1
Crystalship1's Avatar
Hmmm..... I have no idea why you say this as not only do all of the major automakers use this stuff, but I've used it very successfully for years. If done right, this stuff works as designed.
"Seems like common sense isn't that common anymore"
And by the way.... "alot" is NOT a word!!!!
1997 Gunmetal Blue XJ Sport - 4.0 L. I6 - 4 Dr. - 4x4 - 1.75" BB
Crystalship1 is offline
post #14 of 16 Old 06-20-2008, 06:26 AM
kboyts
I agree ^ There must have been an issue with your prep work causeing it to not stick. Try it again, this time being sure to totally remove any of the old tape and adhesive left overs. Scrub the whole thing down with a good was/grease remover, then wipe it down with alcohol before putting on the new tape. One you have everything in place try holding the coners down with some typle of clamps if you can get them on there, if not place a small block of something ontop of the trim to space it out, then tape it down tightly with blue painters masking tape. A little heat from a hair dryer or heat gun will also help kick up the adhesion of the tape to make sure it sticks. Leave it taped up with pressure on it for awhile to be sure the tape has a chance to stick good.
kboyts is offline
post #15 of 16 Old 06-20-2008, 06:27 AM
eflores
1989 XJ Cherokee
horns hisssssss my little chrome A&M emblem has been on since 04 and its held on with 3m tape
AEKDB
Leaky sunroofed XJ member #1
The United States of America July 4, 1776 - November 4, 2008 RIP
eflores is offline
Magic Spark Plugs goldensam XJ Cherokee Technical Forum 10 01-14-2009 05:28 AM
mighty putty JeepinRU XJ/MJ Cherokee Non-Technical Forum 10 08-31-2008 10:19 PM
magic 91xjgawes XJ Cherokee Technical Forum 1 02-10-2006 04:50 PM
Magic leak? muddy bike XJ Cherokee Technical Forum 10 08-16-2004 02:52 PM
hella black magic wildbillxj XJ Cherokee Technical Forum 4 12-24-2003 12:16 PM
