Biggest tire on a stock Rim with 5.5 BS? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Biggest tire on a stock Rim with 5.5 BS?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSuper Low Prices on TJ Bumpers and $399.95 Tire Carriers!Northridge4x4 - Memorial Day Sale
Unread 04-14-2009, 02:24 PM   #1
snakester14
Whats the biggest size Tire you can run on a stock rim with 5.5 BS? I like the look of canyons but would rather just get steeles than have to buy Canyons and Wheels spacers. Id like to run 32x11.50s by the way.
What would I rub on by running 32x11.50s on 5.25 or 5.5 BS?
1998 ZJ 5.2/2inch bb/265 a/ts/Flowmaster SOLD
1996 Stock XJ 4.0/ax-15/231 Traded
1998 4.0/ax-15/231 TJ on 33s SOLD
snakester14 is offline   Reply With Quote
Unread 04-14-2009, 05:23 PM   #2
xjfever
1995 XJ Cherokee
32x1150's will require spacers or aftermarket wheels with 4" backspacing or less. They will also require 4.5" of lift or some fender trimming. 30x9.5 is about as big as you can go on 5.5" backspacing without major rubbing on the lower control arms.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Unread 04-14-2009, 05:25 PM   #3
snakester14
Alright man preciate it
Unread 04-14-2009, 05:53 PM   #4
rockntheXJ
You seem to know your fair share about XJ's, seen you around. I was wondering with an XJ and a 3" lift could 32"11.5 be kinda shoved in with minimal trimming?
rockntheXJ is offline   Reply With Quote
Unread 04-14-2009, 06:51 PM   #5
snakester14
xjfever has a 3inch lift and had 32s on at one point, theirs a pic of it on a thread I started on the same topic. I will be running a similar setup this summer, around 3-3.5 inches and 32s.
http://www.jeepforum.com/forum/f11/how-much-trim-634406/
Unread 04-14-2009, 09:15 PM   #6
Fox Fader
On stock suspension, what the SMALLEST I can go with on a 15x8 soft 8 cragar?
God Rules!
Fox Fader is offline   Reply With Quote
Unread 04-14-2009, 10:03 PM   #7
AuburnXJ
1993 XJ Cherokee
smallest tire? you can run 235s on 15x7 soft 8s put if you want to run a 15x8 i would suggest moving up to 30x9.5
2001 Jeep Cherokee Limited - DD
4.5" Rusty's SA Kit-32x11.5 BFG AT-Super 44 w/ turndown-JKS Discos
1993 Jeep Cherokee - Trail Rig
6.5" Rusty's LA kit-33x12.5 TSL-Pacesetter Header w/Delta 40-JKS Discos-Tom Woods Driveshaft-Advanced Adapters SYE-Custom CAI
Coming This Summer: 44/9", 4 link rear, and 37s
AuburnXJ is offline   Reply With Quote
Unread 04-14-2009, 10:06 PM   #8
AuburnXJ
1993 XJ Cherokee
I run 32x11.50s on my DD and i have a 4.5" lift on and i rub...then again I haven't trimmed my fenders (got another jeep for playin). If you want to actually be able to wheel you'll have to either trim and bumpstop or get a bigger lift because thats one tight sqeeze
Unread 04-15-2009, 03:40 PM   #9
Fox Fader
Thanks, that's what I needed.
God Rules!
