Quantcast bigger mirrors - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > bigger mirrors
Old 03-01-2008, 02:09 PM   #16
XJohnnyC
1992 MJ Comanche
Originally Posted by XJRookie View Post
Bump...trying to get an answer to this as I think I want to try the swap!
I believe that the vast majority of 97+ XJs have electric mirrors. My barebone 98 SE does.
But if you look in Quadratec's catalog, they do list a 97+ "manual remote" model.
XJohnnyC is offline   Reply With Quote
Old 03-01-2008, 02:10 PM   #17
XJohnnyC
1992 MJ Comanche
Originally Posted by 92jeeplaredo View Post
I have 92 jeep cherokee with power mirrors, can i get the newer power mirrors and still be able to use the power switch without any modifications.
Not plug-n-play. You'd have to do some splicing.
Old 09-11-2008, 07:56 PM   #18
XJKyle1389
Originally Posted by ddeadserious View Post
Easy swap. Bolted right up, I had manual mirrors, and these are power, so I just shoved the wire in the door, like said above, and adjusted them once by hand and they've been fine since. These mirrors are definitely bigger, and I recommend the swap.
Olive drab paint?? Looks good. Got any more pics??
XJKyle1389 is offline   Reply With Quote
Old 09-11-2008, 09:45 PM   #19
rocinante
how much bigger are the 97+ mirrors. I just got a 96 and the first thing I noticed is how small the mirrors were for a truck. I assume from this thread the mounts are the same but are the wiring the same too just the connectors different? i.e. same number of wires and the same colors.
What about Grand Cherokee mirrors? bigger, better, compatible?
rocinante is offline   Reply With Quote
Old 09-11-2008, 10:33 PM   #20
ehall
1991 XJ Cherokee
I modified these YJ mirrors for my doorless mod. They could probably be made to work by grinding the base to fit the door and drilling new holes.
Another option would be to mount them directly to the door, although you'd need some kind of internal bracing to keep the door panel from rattling the mirrors.
ehall is offline   Reply With Quote
Glock Forum
