bigger calipers need bigger rims... myth or reality?
#1 | |
I plan on getting some good tires soon, i was gonna stick with my stock rims just cause i need to save some money thou i was gonna go up to 16 inch cause i heard that big brake kits need 16 inchers... but i found no bigger calipers for a cherokee or my year... is this a reality... who makes such big brake upgrades... gimmie some info please!!
1990 Jeep Cherokee Laredo 4.0L Automatic Tranny NP242 Transfer case Dana 30 front, 35 custom rear differentials Mods: RE 4.5" Lift 32x11.50 BFGoodRich M/T KM's American Eagle 058 Polished Aluminum Wheels, 3.63" BS. Grand Cherokee Rear Disc Brake setup Custom Downpipe W/ Cat Removed. Dynomax Super Turbo Muffler. Surco Roof Rack My Jeep |
#2 |
Broke Bogger
Well it depends, their may not be a replacement manufactured that doesn't require new rims, but they do that on purpose, so you don't have to buy new rims. But, if you want a real beefy brake upgrade, you'll probably want 16s, say if your running WJ brakes
stock XJ vs stock WJ ![]()
Matt __________________ 97 XJ - Black Sport, 4.0L AW4, D30 and 8.25 6" Skyjacker/RE, 33x13.5 Swamper LTB Cracked Frame, good for steering!!! MY XJ PICS |
#3 |
Location: allentown, pa(home) west chester, pa (school)
the reality of it is you cant get bigger breaks for an xj/tj/yj/zj front axle unless you get a new axle or do th wj conversion.
The best bang for your buck in a 90 would be converting to rear disk's along with swapping the 95 mc/booster I've done one on one jeep and one on the other jeep, and both make big differences alone, i like the rear disc first because they actually do something. And keep the tires from locking up. Oh and some wheels wont fit some will, fullsize trucks use much larger brakes and 15 in wheels still
94 xj, 36s, 4" lift, 8.8, 4.10s, oba, tj flares.... http://xjfanatic.com |
#4 |
i dont intend to convert to WJ calipers, but i have put on 96 zj rear discs and im in the process of getting 96 jz master cylinder, double d booster and proportioning valve to swap out the remaining bo 4 wheel disc components. and while she stops excellent now... i want to do this so i can maintain it with bigger tires down the road. thanks for your help.. it sounds like if i cant afford new rims i can reuse my old ones
#5 |
is there a tech write up on the WJ disc brake conversion?
#6 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
