BIG MISTAKE, 1996 Cherokee sport - JeepForum.com
post #1 of 6 Old 08-14-2012, 10:55 PM Thread Starter
jefe0792
So I was replacing the spark plugs of my cherokee sport I just got because they were having problems misfiring, and I accidently hooked a spark plug wire to the coil, and the distributor wire to a spark plug. When I started the car in the wrong firing order I know that must have shorted the system, and the car had a really bad start, then all the lights and electronics shut off and I found I blew a fuse from instrument panel. I fixed the distributor once I realized my mistake, replaced the fuse and tried again. Hooray it started well the first time, but then after I shut it off I tried a second time, and everything went dead again, lights and everything with no crank but an audible click as the lights went off. The lights returned after a short period of time but now I can no longer start it and the problem repeats itself. I think its very possible I triggered some relay or something electrical that has to be the cause.
Any ideas of what I really did to the electrical components or what I need to look at to see what the problem is?
jefe0792 is offline
post #2 of 6 Old 08-14-2012, 10:59 PM
youarestuck
Mine does the same thing when the battery is dead
youarestuck is offline
post #3 of 6 Old 08-14-2012, 11:00 PM
rosco219
Sounds like a nightmere.....sorry for your loss
rosco219 is offline
post #4 of 6 Old 08-14-2012, 11:08 PM
Tylerzap
My MJ does that when the battery is dead or not getting a good connection. Try to charge it, if it work charge, there's your problem.
My 98 XJ "Zap" Build Thread
1988 Jeep Comanche 4x4 Longbed - POS
Tylerzap is offline
post #5 of 6 Old 08-15-2012, 05:21 AM
Carl48
x3 on the battery/charging system...a temporary coil secondary misconnection shouldn't cause the no start issues you are experiencing.
Carl48 is offline
post #6 of 6 Old 08-15-2012, 01:24 PM
wpb98xj
Check your battery cables, a loose or dirty battery connection, postive or negative will cause same symptoms you descibed.
wpb98xj is offline
cherokee , electrical issue , relays , spark plugs
1996 Jeep Cherokee Sport GravyTrain7 XJ Cherokee Technical Forum 11 03-13-2017 06:11 PM
1996 cherokee sport robertconner XJ Cherokee Technical Forum 1 12-31-2011 01:46 PM
1996 jeep cherokee sport ? woowoobubba XJ Cherokee Technical Forum 1 07-28-2011 11:05 PM
Starter - 1996 Cherokee Sport rdm7938 XJ Cherokee Technical Forum 27 02-11-2010 05:29 AM
Need Help 1996 Cherokee Sport nmblkmtn1 XJ Cherokee Technical Forum 7 02-11-2007 06:04 PM
