-   -   BIG MISTAKE, 1996 Cherokee sport (http://www.jeepforum.com/forum/f11/big-mistake-1996-cherokee-sport-1405539/)
jefe0792 08-14-2012 11:55 PM
So I was replacing the spark plugs of my cherokee sport I just got because they were having problems misfiring, and I accidently hooked a spark plug wire to the coil, and the distributor wire to a spark plug. When I started the car in the wrong firing order I know that must have shorted the system, and the car had a really bad start, then all the lights and electronics shut off and I found I blew a fuse from instrument panel. I fixed the distributor once I realized my mistake, replaced the fuse and tried again. Hooray it started well the first time, but then after I shut it off I tried a second time, and everything went dead again, lights and everything with no crank but an audible click as the lights went off. The lights returned after a short period of time but now I can no longer start it and the problem repeats itself. I think its very possible I triggered some relay or something electrical that has to be the cause.
Any ideas of what I really did to the electrical components or what I need to look at to see what the problem is?
youarestuck 08-14-2012 11:59 PM
Mine does the same thing when the battery is dead
rosco219 08-15-2012 12:00 AM
Sounds like a nightmere.....sorry for your loss
Tylerzap 08-15-2012 12:08 AM
My MJ does that when the battery is dead or not getting a good connection. Try to charge it, if it work charge, there's your problem.
Carl48 08-15-2012 06:21 AM
x3 on the battery/charging system...a temporary coil secondary misconnection shouldn't cause the no start issues you are experiencing.
wpb98xj 08-15-2012 02:24 PM
Check your battery cables, a loose or dirty battery connection, postive or negative will cause same symptoms you descibed.
The time now is 01:03 AM.
