Big Camshaft? - JeepForum.com
post #1 of 35 Old 10-13-2010, 06:32 AM Thread Starter
Sturmsoldaten
1990 XJ Cherokee
Big Camshaft?
so my jeep has 150k and it is getting pretty tired and i am getting amped to do a rebuild. i am from a muscle car family and that means we do a big cam whenever we get the chance. i was wondering whats the biggest cam i can do in my 4.0l without messing with the EFI?
Sturmsoldaten is offline
post #2 of 35 Old 10-13-2010, 07:35 AM
lowicz96
1995 XJ Cherokee
150K is nothing for the 4.0L, i'm about to break 210K and I get plenty of power still. Once in a while ill roast the tires or bounce it off the rev limiter from stop lights just for fun.
There isnt much in the way of aftermarket parts like there is for 5.0 or 350. Most dont bother with cam swaps unless you stroke it out to 4.5L+.
The EFI on any jeep before OBDII is super easy to make work with any setup on the 4.0L
Project/DD - 95' Cherokee Sport, 2 Door, Converted to 4x4, AX-15, NP231, Black and lots of other goodies
88' Cherokee Limited - RIP
Sold - 96' Cherokee Sport 4x4, 2 Door, AW4, NP242, Its the girlfriends now!!
lowicz96 is offline
post #3 of 35 Old 10-13-2010, 07:51 AM
RockRodHooligan
RockRodHooligan's Avatar
I had been looking into this myself when I was just going to do a ported and polished intake, head, header, and cam. Found out that the cam I had been looking at if I would stroke it, would work just fine with just a free flowing top end.
COMP Cams K68-231-4 - COMP Cams Xtreme Energy 4x4 Cam and Lifter Kits - Overview - SummitRacing.com
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
post #4 of 35 Old 10-13-2010, 07:54 AM
alexrule123
alexrule123's Avatar
To give you an idea of the power increase from a cam, the Mopar Stage 2 cam would give around a 10 hp gain according to the Mopar Jeep Engines book I have.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #5 of 35 Old 10-13-2010, 08:02 AM
dukie564
dukie564's Avatar
1995 XJ Cherokee
But it's more about the SOUND of a large cam engine
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #6 of 35 Old 10-13-2010, 08:56 AM
djb383
An XJ that thumpty lumped like this would be cool.
YouTube - worked 202 idle
djb383 is offline
post #7 of 35 Old 10-13-2010, 11:33 AM
Mkonyn
this ^
Mkonyn is offline
post #8 of 35 Old 10-13-2010, 12:56 PM
Diamond-x
1991 XJ Cherokee
I have the Comp Cams 68-231-4, it creates a lot of power. Some people have had troubles with thier lobes going flat due to the lack of ZDDP in motor oil. For the first 4 oil changes I added redline ZDDP additive and have had zero troubles. ZDDP also contains zinc which coats the cat and hinders it's function, FYI.
That motor ^^ is cool! but only because it sounds like a V8. A Carb setup is not the best for offroading.
Diamond-x is offline
post #9 of 35 Old 10-13-2010, 01:02 PM
dukie564
dukie564's Avatar
1995 XJ Cherokee
you mean the 68-232-4? 68-231-4 is not for fuel injected engines
dukie564 is offline
post #10 of 35 Old 10-13-2010, 03:05 PM
RockRodHooligan
Too bad guys have been using it on fuel injected engines for quite some time now. What's even better, is that it lists the 4.0L in the applications, the 4.0 was never carbureted.
96 XJ:
***** inches...
post #11 of 35 Old 10-13-2010, 03:10 PM
dukie564
dukie564's Avatar
1995 XJ Cherokee
i dunno...just reading what is said in capital letters
dukie564 is offline
post #12 of 35 Old 10-13-2010, 04:57 PM
Diamond-x
1991 XJ Cherokee
I have this cam in my 4.6 stroker fuel injected motor. I have only good things to say about it!
post #13 of 35 Old 10-13-2010, 05:36 PM
djb383
Originally Posted by Diamond-x View Post
.......Some people have had troubles with thier lobes going flat due to the lack of ZDDP in motor oil.........
Any confirmation of this actually occurring on a Jeep 4.0?
djb383 is offline
post #14 of 35 Old 10-13-2010, 06:28 PM Thread Starter
Sturmsoldaten
1990 XJ Cherokee
that is the cam i had in mind, will that work without messing with my ECU or EFI?
post #15 of 35 Old 10-13-2010, 07:51 PM
BeepBeepGoJeep
1994 XJ Cherokee
id like to cam mine also one day, and will probably go with that one ^
[]IIIII[]
BeepBeepGoJeep is offline
Camshaft Bearings ArmyFireFighter XJ Cherokee Technical Forum 11 09-21-2012 07:10 PM
4.0L camshaft UltimatE XJ Cherokee Technical Forum 4 10-07-2007 10:17 PM
camshaft USA_PRIDE XJ Cherokee Technical Forum 3 01-04-2007 07:25 PM
which camshaft? Please help Jeepcherokeeboy XJ Cherokee Technical Forum 9 10-17-2006 05:19 PM
camshaft for 93 4.0 93cherokee4.0 XJ Cherokee Technical Forum 3 11-15-2005 05:11 PM
