Best way to jack up the front end? - JeepForum.com
post #1 of 8 Old 04-26-2011, 10:06 PM Thread Starter
MagicNelson
Forgive me if this is a stupid question but what's the best way to jack up the front end of an XJ? I've used the differential as a lift point in the rear but the front diff is off-center so that won't work. I'm used to being able to find a spot on the frame to use but I didn't see anything that I thought would be safe. The owners manual isn't exactly clear on this subject either so I'd figure I'd ask you guys.
MagicNelson is offline
post #2 of 8 Old 04-26-2011, 10:35 PM
JFcavedweller
axle tubes, probably best to do one end at a time and use jackstands before switching sides, as opposed to once at the middle. let the unibody rest on the jackstands
O|||||||O - '99 TJ
■|||||||■ - '97 ZJ
JFcavedweller is offline
post #3 of 8 Old 04-27-2011, 12:47 PM Thread Starter
MagicNelson
Ok thats what I've been doing but I was curious to see if someone came up with a better way.
post #4 of 8 Old 04-27-2011, 01:03 PM
JFcavedweller
one of many great things about solid axles: a jack point parallel to the ground. imo axles for lifting, frame (in this case the reinforced part of the unibody) for resting
O|||||||O - '99 TJ
■|||||||■ - '97 ZJ
post #5 of 8 Old 04-27-2011, 01:07 PM
lowicz96
1995 XJ Cherokee
I just put the jack in the middle of the front axle to jack it up, right on the axle tube. Doing one side at a time takes too long
Project/DD - 95' Cherokee Sport, 2 Door, Converted to 4x4, AX-15, NP231, Black and lots of other goodies
88' Cherokee Limited - RIP
Sold - 96' Cherokee Sport 4x4, 2 Door, AW4, NP242, Its the girlfriends now!!
lowicz96 is offline
post #6 of 8 Old 04-27-2011, 01:35 PM
JFcavedweller
^ yeah i guess with the bottle jack that would be so annoying one side at a time... im thinking floor jack
O|||||||O - '99 TJ
■|||||||■ - '97 ZJ
post #7 of 8 Old 04-27-2011, 03:28 PM
Wearingthin
I just put a floor jack under the diff, sure it lifts it all off cantered like, but oh well.
Patriot Blue XJ 4x4
RE 4.5" | 305/70/16 MTR K
Wearingthin is offline
post #8 of 8 Old 04-27-2011, 03:59 PM
lowicz96
1995 XJ Cherokee
I mostly use the floor jack too. why pump the jack twice as much as you need to?
lowicz96 is offline
Removing Front LCA Question.. Jack Placement gtospeeding XJ Cherokee Technical Forum 12 09-21-2009 08:05 PM
High Lift Jack (farmers Jack) Jacking points pocquet MJ Comanche Technical Forum 10 03-16-2009 09:16 PM
what floor jack and jack stands should i get for my XJ mattathayde XJ/MJ Cherokee Non-Technical Forum 12 11-08-2008 09:39 AM
can I use my front/rear bumpers with a hi lift jack? BigOrangeXJ XJ Cherokee Technical Forum 9 05-09-2007 10:34 AM
How to jack front end... BeachinXJ XJ Cherokee Technical Forum 13 03-23-2004 07:22 AM
