best way to get window tint glue off? - JeepForum.com
post #1 of 15 Old 03-11-2008, 07:43 AM Thread Starter
medicbear
I tried windex, pb blaster they work kinda but not that great.. And this stuff STINKS!!!! I got most of the tint off minus a few small areas where the 2 layers seperated.... Any tips to get the gunk off i know the rest of the film i just need a straight razor and be careful on the defrost lines... if the defrost line gets cut only once is it still ok?
OEF Vet still serving.
2007 Sahara Unlimited Stock for now
True Story while she was driving my XJ: "Honey hold my slurpee and watch this!"-My wife
come check us out
medicbear is offline
post #2 of 15 Old 03-11-2008, 07:56 AM
JDeke
I've always had good luck using the gojo hand cleaner with pumice in it.
JDeke is offline
post #3 of 15 Old 03-11-2008, 08:24 AM
paulmatyn
paulmatyn's Avatar
1992 XJ Cherokee
amonia works great. and if you nick one of the defroster lines it will still work, just not that one line. but you can get conductive paint and repair it.
Originally Posted by Beefstew View Post
brain guts all over the windshield!!!!!!!!!!!!!!!!
Originally Posted by WillysEdition04 View Post
After reading 7-8 of your posts I've come to the conclusion that you may be mentally retarded, which is why I won't ask what "brain guts" are.
Originally Posted by Duck Dodgers View Post
I'd rather take the chance and belive in God than take the chance and not.
Cuz ya got nothing to lose by believing, but ya sure might if ya don't.
White Jeep Club Member-2027
paulmatyn is offline
post #4 of 15 Old 03-11-2008, 08:57 AM
xxxflhrci
xxxflhrci's Avatar
Windex with ammonia will make it loosen and turn into balls of goo when you scrape it with a razor blade.
xxxflhrci is offline
post #5 of 15 Old 03-11-2008, 08:57 AM
BigD 275
A straight razor and soapy water solution. That is what the tint shop around here does when they take old tint off. Spray the solution on, and very slowly scrap the glue off. Works really well.
99 Jeep Cherokee Limited
BigD 275 is offline
post #6 of 15 Old 03-11-2008, 08:59 AM
Snacks
Little buddy
Snacks's Avatar
Are you taking it off to go darker or just taking it off?
Nick
“I had nothing to offer anybody except my own confusion” Jack Kerouac
Snacks is offline
post #7 of 15 Old 03-11-2008, 09:09 AM Thread Starter
medicbear
i took it off cause it wasnt oem it was some **** job someone did and faded green in some areas... i dunno if ill put more on or not...
come check us out
post #8 of 15 Old 03-11-2008, 01:37 PM
afbond03
afbond03's Avatar
When I had to take 14yr old tint off my 300zx my brother whom tints for a living suggested goo gone and a straight razor..yep..took it right off tint and glue so you don't have to do one and then the other. Works magic.
You know Jesus wasn't married. No wife lets you come home after three days with the excuse "I was dead".
afbond03 is offline
post #9 of 15 Old 03-11-2008, 01:46 PM
Crystalship1
Crystalship1's Avatar
MedicBear,
This is what you need: http://doitbest.com/Main.aspx?PageID...FQRexgodii1O9Q
NOT a "Straight Razor": http://www.venusworldwide.com/razor_8.htm
Scrape away!!!
"Seems like common sense isn't that common anymore"
And by the way.... "alot" is NOT a word!!!!
1997 Gunmetal Blue XJ Sport - 4.0 L. I6 - 4 Dr. - 4x4 - 1.75" BB
Crystalship1 is offline
post #10 of 15 Old 03-11-2008, 02:01 PM
BigD 275
Originally Posted by Crystalship1 View Post
MedicBear,
Scrape away!!!
Didn't mean that "straight razor". An actual razor blade, the "old school" ones. Those work like a charm and are easy to control. Like I said, the tint shops around here use this method.
BigD 275 is offline
post #11 of 15 Old 03-11-2008, 02:25 PM
bluballer
1990 XJ Cherokee
I've had great luck using Ooops.... on a variety of adhesive removal jobs....no blades...no razors.... rub it off....I get it from autozone locally...
http://paint-and-supplies.hardwarest...er-101295.aspx
Check out my cardomain site: Cher"red"Kee @
Street Jeep tip #1: The more inspiring your ride the more you'll get hated on by simpletons.
Haters only link:
bluballer is offline
post #12 of 15 Old 03-11-2008, 06:15 PM
traylor4x4
Lighter fluid thats not a joke just don't light it
traylor4x4 is offline
post #13 of 15 Old 03-11-2008, 08:09 PM
dsfdf19
1994 XJ Cherokee
"Goo Gone" I think you can buy it at walmart or prob. an autoparts store its great stuff I used it to take off the funkie stripe on the bottom of my XJ
1994 Jeep Cherokee SE 2 Door
6.5 Rustys leaf pack
33-12.50 15 D.C. Crushers
15x10 Rockcrawler Wheels
The Jeep Build W/lots of Pic's
dsfdf19 is offline
post #14 of 15 Old 03-11-2008, 08:20 PM
minitruck83
1994 XJ Cherokee
HD single edge, meant for use in a scraper is best. The double edge blades will snap and cut you before you know it. Either throw it away after you've finished or tape the edge,cause if you don't and just toss it in your toolbox it'll get you sooner or later.
I'll second the lighter fluid/naphtha suggestion. It'll dissolve plastic.
Allen
minitruck83 is offline
post #15 of 15 Old 03-11-2008, 09:04 PM
sbrunner
Aren't the straight razor's gonna tear up all his defroster lines? I just coat it with window cleaner and rub it off with a window rag. Took awhile but I didn't damage any defroster lines.
sbrunner is offline
Window Tint, How To ? 01JeepXJ XJ Cherokee Technical Forum 19 10-05-2011 07:55 PM
Window tint on the back window?? marinefreak200 XJ/MJ Cherokee Non-Technical Forum 16 05-23-2009 09:51 PM
window tint acmech13 XJ Cherokee Technical Forum 10 02-07-2009 12:34 PM
Window tint MaddieXJ XJ Cherokee Technical Forum 3 11-26-2004 02:06 AM
window tint joshbish XJ Cherokee Technical Forum 21 09-01-2004 09:38 PM
