Best Tie Rod Choice for the Money - Page 2 - JeepForum.com
post #16 of 20 Old 06-23-2010, 11:48 PM
justanotherjpr
The issue I have with the Crown setup and the ZJ swap is the additional adjustment sleeve added at the driver's side knuckle, and the fact that the TRE at the drag link is part of the tie rod itself. With the IRO (or another HD tie rod setup) the tie rod ends are individually replaceable - the stockers can be carried as spares and swapped in if needed. You could do this with the other setup, if you wanted to carry the stock tie rod as well, I suppose.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #17 of 20 Old 06-24-2010, 05:10 AM Thread Starter
DillsburgXJ
I am trying to get away from those adjuster sleeves. I read about them stripping out on people and needing to be replaced. It looks like a good set up, but I'd rather have the adjustment coming from the ends.
2000 XJ
4" Old Man Emu / JKS (ACOS and Shackle)
Iron Rock adjustable upper and lower control arms
Iron Rock double shear track bar
Crown HD Steering upgrade
C-Rok steering brace...
DillsburgXJ is offline
post #18 of 20 Old 06-24-2010, 10:44 AM
justanotherjpr
This is a good call. I carry a spare one on the trail because I haven't rid myself of the upper one yet.
post #19 of 20 Old 06-24-2010, 01:19 PM
smokinlib1
1990 XJ Cherokee
Yeppers, I've seen like oh, none of them stripped out in the rocks. But if you want to spend another $200 on a HD set up like Currie makes, by all means go for it! Put the adjusters up and out of the way, use a tie rod flip and do your own alignments and see how long it takes for those adjusters to strip. Just my $0.02
1990 XJ Cherokee
1995 XJ Cherokee
smokinlib1 is offline
post #20 of 20 Old 06-24-2010, 04:52 PM Thread Starter
DillsburgXJ
I'm not considering the Currie set-up as it is pricey and WAY more than I need. Obviously the set-up you are running works for you smokinlib1. I was simply stating info I read on the forum. I'm glad to hear you like your set-up. I think I'll be happy with the IRO set-up
2000 XJ
What's Your Choice??????? yankeeboy XJ Cherokee Technical Forum 9 03-25-2006 02:18 PM
Best Choice SmittysXJ XJ Cherokee Technical Forum 15 05-23-2005 07:05 PM
help with lift choice brad31684 XJ Cherokee Technical Forum 7 04-15-2005 03:36 PM
Choice of tires SmittysXJ XJ Cherokee Technical Forum 10 01-19-2005 01:13 PM
rim choice help bj-666 XJ Cherokee Technical Forum 4 07-11-2004 12:29 PM
