Quantcast Best Super Cheap Modifications? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Best Super Cheap Modifications?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 09-11-2008, 10:53 PM   #1
9pt0
I picked up a 98 Cherokee Limited about 6 months ago for an embarrassingly low price. The rear brakes were shot at the time, but it's currently running and driving nicely. I've added a pair of off road lights and good tires, and now I'm looking for something else to do to it. It's mainly a winter vehicle, but I'd like get into some light off-roading as well.
What are some of your favorite free/cheap modifications or additions?
9pt0 is offline   Reply With Quote
Old 09-11-2008, 10:55 PM   #2
bigbike
1995 XJ Cherokee
Doorless FTW
bigbike is offline   Reply With Quote
Old 09-11-2008, 10:57 PM   #3
9pt0
Originally Posted by bigbike View Post
Doorless FTW
As fun and entertaining as this would be, it would probably get a bit chilly
Old 09-11-2008, 11:00 PM   #4
littleblackXj
1993 XJ Cherokee
Tits a bit
1993 Jeep Cherokee
Rubicon Express 4.5" Lift
33" Wrangler Duratracs
30/44 4.88s Disks all around
Detroits F&R
littleblackXj is offline   Reply With Quote
Old 09-12-2008, 12:03 AM   #5
ep191
fender trimming ftw
ep191 is offline   Reply With Quote
Old 09-12-2008, 12:11 AM   #6
BrunoS
hi-flow muffler. factory unit robs around 5 hp. no bull. it will be the single most worthwhile upgrade you can do for around 40-70$.
there's more...but start with that!
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline   Reply With Quote
Old 09-12-2008, 12:18 AM   #7
Topgun514
1988 XJ Cherokee
http://www.go.jeep-xj.info/HowtoSilencer.htm
do that
or that plastic peice infront of the air dam, just pull em out
87 XJ pioneer-Totalled
96 XJ Sport- Sold
Now: 88 RENIX 4.0 XJ, Project Overlander
3.5" Lift, RE SF LCA's with skids, 31x10.50R15 Duratracs, ARB Roofrack, Custom Bumper, Glasspack, Bored TB, Custom seats
Topgun514 is offline   Reply With Quote
Old 09-12-2008, 12:18 AM   #8
9pt0
the exhaust has at least a couple holes in it (right before cat, etc), so I've got to patch it up somehow (jb weld?). New muffler at the same time would be a good idea. Summit Racing has some house-brand mufflers for ~$40. Any recommended mufflers?
Old 09-12-2008, 12:23 AM   #9
9pt0
Originally Posted by Topgun514 View Post
or that plastic piece in front of the air dam, just pull em out
I'm not sure what this refers to, or what it would do. Could you clarify?
Old 09-12-2008, 12:51 AM   #10
Topgun514
1988 XJ Cherokee
look right infront of your air intake mouth and there is a peice of plastic infront held in by 3 screws. Take it out, it gets a tad better airflow
96 XJ Sport- Sold
Old 09-12-2008, 01:03 AM   #11
BrunoS
it's called a bugshield, behind left front headlight.
also drill some 2 or 3" air holes in bottom air filter box up front on the battery side.
this is a noticeable upgrade and is felt on the freeway above 45 mph.
Old 09-14-2008, 02:06 AM   #12
BigBearXJ
DIY headlamp harness. Totally worth it, even with the stock sealed beams. I did mine a few years ago for around $60 grand total.
grab a cheap CB off craigslist and install it
Ive never been impressed with the stock back up lights, so i grabbed a $10 set of fog lights from wal-mart, and wired them into the reverse light circuit with a relay. reversing at night is much better now.
im sure ill think of more...
Eat, Jeep and be Merry.
BigBearXJ is offline   Reply With Quote
Old 09-14-2008, 08:48 AM   #13
Irongrave
i'd make sure all your mechanical stuff is good, plugs wires, cap, rotor, filter, and that kind of stuff if its your daily in the winter you want it to run and get you where you need to go. if your getting into offroading make sure you have front and rear recovery points.
2006 Ram 1500, towhore, intake tune 285 70 17 KM2s 2001 18' Parker, crawler hauler
1997 TJ, Dad's Claytons 4:88s and stuff A TJ for Dad
1996 XJ, Gf's Project low on green
1992 YJ crawler, Caged, locked, ready to rock, on 33in pitbull rockers . Build thread the illusion of progress
North Jersey Jeep Club Secretary
Irongrave is offline   Reply With Quote
Old 09-14-2008, 09:41 AM   #14
MXdude105
i got a summit muffler, clamps, and flexpipe for under $40. Definately feels a bit crisper and is barely louder.
-2000 XJ Cherokee Sport 4x4. 4.0L, NP231, c8.25, aw4, RC 3" AAL........SOLD
-1995 Mustang GT 302
MXdude105 is offline   Reply With Quote
Old 09-14-2008, 02:45 PM   #15
ahewy
ebays got a 2 inch rough country lift kit. shackles for rear and spacers for front. 89 bucks i think. buddy just got it for his jeep. ive seen ppl that mod their airbox to just block off hot air and put a cone filter in. hood vents are cheap. i just bought 2 deck drains for a boat. they're black plastic and im gonna add that above my afe cai to get cooler air. those were 5 a piece and should look b.a. after.
ahewy is offline   Reply With Quote
Glock Forum
