Best starter to buy - JeepForum.com
post #1 of 15 Old 01-07-2008, 09:45 AM Thread Starter
cnskate
Best starter to buy
My starter was replaced a little over a year ago and cranks like a champ usually, but the solenoid is crappiing out. Had to do the hammer tap thing last night. I can get a new solenoid for $40 locally, or a new, not remanufactured Napa or Bosch for $140. A very reputable local shop also sells an in house rebuilt one for $130. I'm planning some big backcountry trips for this car, so reliablity is key. Which starter would you choose?
94 4.0 auto 231 w/ 3" OME lift & Tomken discos & Mombasa Excursion Roof Top Tent
cnskate is offline
post #2 of 15 Old 01-07-2008, 10:18 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
If reliability is key, then no question....buy a NEW starter with solenoid. Hate to replace the solenoid only to find that the starter itself craps out of you when you are in timbuktu. You could probably get by with just replacing the solenoid though as your starter is only a year old.
Here's how I rate replacement hardware:
#1. Brand New
#2. Remanufactured (everything inside must meet OEM factory specs generally)
#3. Rebuilt. I'm not crazy about rebuilt stuff as in my experience, it's hit and miss. Sometimes you get a good one, sometimes you don't. Rebuilt is not the same as remanufactured. Rebuilt "generally" means only that the piece has been repaired to the level of failure. That means that there might be something else inside that is marginal that could go out in another month. I generally have better things to do with my time than to perform the repair twice so unless I'm having trouble coming up with enough coin for the gas bill, I don't buy rebuilt stuff.
My 2 cents!
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #3 of 15 Old 01-07-2008, 10:32 AM Thread Starter
cnskate
I think I'll just get the new one. I just talked to the dealer parts guy and he said that the remanufactured ones don't last very long, which is my experience. He said that the main reason for failure is them getting oil saturated.
cnskate is offline
post #4 of 15 Old 01-07-2008, 10:58 AM
fedrusion
The hammer and tap useually indicates that the starter motor itself is going bad, definetly find a diferent starter and not just replace the solenoid.
1999 Cherokee 2 Door Sport (To be modified) Mine.
5.5" Composite lift, Rough Country Control Arm Drop Brackets, 31X10.5X15 Dayton Timberline AT's On Canyons, 31X10.5 Firestone Destination MT's, P.O.R.C. SYE and front CV Drive Shaft, Homemade Short Ram Intake, Locked 8.25. Comming Soon: Stroker.
2000 Grand Cherokee Laredo (To be left alone) Wife's.
fedrusion is offline
post #5 of 15 Old 01-07-2008, 11:05 AM
Blue XJ
Blue XJ's Avatar
1988 MJ Comanche
I replaced mine with the lifetime warranty one from Autozone. The new one lasted about 3 years and then seized up after sitting for a while. banged on it with a hammer to get it to crank, it worked fine for a few weeks after that, but I took it in and had them give me a new one, just so I didn't have to replace it in the middle of winter when it seizes for good.
'88 MJ
Blue Jeep Club Member #72
| 4.6L Stroker | AW4 | 6.5" RK Long Arm Kit | 35" TruXus MT's | HP30, 4.56, ARB, Alloys, Lockouts | C8.25, 4.56, ARB, Alloy Shafts, Disk Brakes | Warn XD9000i | Interior Cage |
Blue XJ is offline
post #6 of 15 Old 01-07-2008, 01:47 PM
Blurple
Just repaired my starter over the holidays. Way cheaper than replacing. All it needed was a new bendix. $26 Canadian and about 1.5 hours work.
You could hear the starter spining well, but it was not engaging 100% of the time. Took 2 or 3 key turns for the starter to engage. Never needed to use the hammer tap so it may not be exactly what you need.
Blurple is offline
post #7 of 15 Old 01-07-2008, 04:34 PM
staggwj
what is the hammer trick that you guys are talking about? sorry if im a n00b
'99 I-6 WJ
Stock
'88 I-6 MJ
Stock for now
staggwj is offline
post #8 of 15 Old 01-07-2008, 07:07 PM
creaky70
When the starter and/or solenoid is going bad, and the starter won't engage when the key is turned to start, holding the key in the start position and having an assistant rap the starter with a hammer will usually cause the starter to operate if nothing else is wrong.
creaky70 is offline
post #9 of 15 Old 01-08-2008, 06:19 AM
Blue XJ
Blue XJ's Avatar
1988 MJ Comanche
What is a new bendix? Bendix is a brand, not a part?
'88 MJ
Blue XJ is offline
post #10 of 15 Old 01-08-2008, 06:47 AM
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
Here's a basic explanation:
http://www.ctci.org/membership/Gilsg...rterBendix.htm
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline
post #11 of 15 Old 01-08-2008, 07:39 AM
Blurple
To add further:
Originally Posted by Wikipedia
The Bendix drive is still in widespread use at the beginning of the 21st century, so much so that mechanics often refer to such a mechanism simply as a "bendix".
Bendix on Wikipedia
Kind of like Kleenex, how often do you hear someone ask for facial tissue?
Blurple is offline
post #12 of 15 Old 01-08-2008, 07:56 AM
TMCXJ
Another thing to check is the heater control valve which is located a little more than a foot directly above the starter. This valve, if original equipment, is garbage. It becomes brittle and porous and can leak a little or a lot. Leaking a little is what can actually be more destructive than leaking a lot since if it was a very noticeable leak, you'd get right on it and replace it, but leaking only a little or not even so's you'd notice, well it just goes on doing damage to the starter. Drip. Drip. Drip...
Ask me how I know....
For a long long time, on my 1991, I thought I had serious internal engine problems because every once in awhile there'd be this high-pitch metallic clanging, chipping noise coming from the engine. I had no idea what it was until I changed the starter (ruined per the above described "little leak" process) and found that the innards of the starter were so bad... the spring/starter drive ("Bendix," LOL!!) had corroded, weakened, and broken, and the gear was free to slide along the motor shaft (which was also responsible for the screaching when trying to start and the failure to engage the teeth to crank the engine). And, when the motor was running, the gear would slide along said motor shaft and contact the teeth in the flywheel gear, causing the odd "engine" noises. Once the starter was replaced, and the control valve at the same time, WOW! what a great enginge I had, LOL! Sadly, the beast was wrecked not too many months later. Actually, exactly one year ago tonight, at 6:18 PM...
Sorry for the usual long post from me, but I thought it might help the OP and maybe others as well.
"...a long habit of not thinking a thing wrong, gives it a superficial appearance of being right, and raises at first a formidable outcry in defense of custom. But tumult soon subsides. Time makes more converts than reason." Thomas Paine
TMCXJ is offline
post #13 of 15 Old 01-08-2008, 07:57 AM
Blue XJ
Blue XJ's Avatar
1988 MJ Comanche
To add further:
Bendix on Wikipedia
I don't get internet access at work here, except for sites with chrysler, dodge or jeep in the title, so thanks for the explanation since I wasn't able to look it up.
'88 MJ
Blue XJ is offline
post #14 of 15 Old 01-08-2008, 02:57 PM Thread Starter
cnskate
After the hammer whack it's worked several times. I'm not taking any chances though. Bought a brand spanking new one from Napa for $123 with my AAA discount.
cnskate is offline
post #15 of 15 Old 01-08-2008, 03:04 PM
Crystalship1
Crystalship1's Avatar
Good move!! Now you've got a new one with a nation-wide warranty!!
"Seems like common sense isn't that common anymore"
And by the way.... "alot" is NOT a word!!!!
1997 Gunmetal Blue XJ Sport - 4.0 L. I6 - 4 Dr. - 4x4 - 1.75" BB
Crystalship1 is offline
Why won't my Jeep start after new starter? (starter works, no spark??) DuaneJ XJ Cherokee Technical Forum 12 02-13-2012 02:45 PM
Starter Bad? mfinkler XJ Cherokee Technical Forum 5 11-24-2009 06:17 PM
Where is the starter? 88 xj Thmastr XJ Cherokee Technical Forum 13 12-06-2008 12:24 AM
Starter? Starter Relay? bills79jeep XJ Cherokee Technical Forum 16 05-10-2007 02:09 PM
Starter? mdonohu1 XJ Cherokee Technical Forum 4 01-04-2007 06:47 AM
