Best Preventative maintenance for 4.0? - JeepForum.com
post #1 of 16 Old 11-02-2009, 10:27 AM Thread Starter
JustEatEvryPart
What does everyone think the best preventative maintenance for 4.0 cherokees is? Not just the engine, but the suspension, unibody, etc.
JustEatEvryPart is offline
post #2 of 16 Old 11-02-2009, 10:47 AM
cornbrizzle
1992 XJ Cherokee
change fluids regularly, keep all joints greased,and check all joints for play and tightness, and check bushings for wear.
Brizzle
“Don’t Tread On Me”
www.highsprings.com
cornbrizzle is offline
post #3 of 16 Old 11-02-2009, 10:49 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Follow the routine preventative maintenance and service intervals in your owners manual. If you don't have one, stop by the junkyard or look on eBay.
Wash your Cherokee often, paying extra attention to the wheel wells and underbody. Just look at any old rusty Cherokee. Self service car washes are better than the drive through ones. Wax the paint every fall and spring.
CJ7-Tim is offline
post #4 of 16 Old 11-02-2009, 10:53 AM
99Greenmachine
Good advice...
The owner's recommendation of maintenance is there for a reason.
'99 XJ Sport
Thank You Hooligan!!!
[SIZE="4"]XJ Dana 44, Yukon 4.56 D44 Gears, LeBaron hood vents for sale
99Greenmachine is offline
post #5 of 16 Old 11-02-2009, 05:26 PM Thread Starter
JustEatEvryPart
Great stuff guys. Any advice on preventative maintenance in the trails? As far as breaking parts goes? Any parts that break more often than others?
post #6 of 16 Old 11-02-2009, 05:40 PM
corndogduff
Here's my advice... Don't jump it. I had a fairly smooth riding setup till I caught some air, now I have a bent control arm and occasional DW that would make Chuck Norris crap himself.
Luckily though, almost everything important is replacable and interchangable from 1987-2001
Duff.
(broken)98 ZJ 5.9
UT Jeepcrew #13
NIGHTCREW
corndogduff is offline
post #7 of 16 Old 11-02-2009, 06:32 PM
Dogberri
1991 XJ Cherokee
i have heard people say that the starters in the 4.0's go out often but i dont know how accurate that is
Dogberri is offline
post #8 of 16 Old 11-02-2009, 06:39 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I have had to replace my starter once in 125000 miles, I wouldn't call that often. Had a YJ with 165,000 and the origional starter.
xjfever is offline
post #9 of 16 Old 11-02-2009, 06:58 PM
AZ Jeff
2014 JK Wrangler
NOT TRUE......unless you let your battery cables and/or battery deteriorate to the point that the battery draws excessive CURRENT trying to make up for lost VOLTAGE. THAT kills a starter QUICKLY, no matter WHAT brand of vehicle you drive.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #10 of 16 Old 11-02-2009, 07:03 PM
Smittyman
Coolant system is always great to keep tabs on. You have a 99 though, so you don't have to worry about crackin a head like a 00 or 01 Xj if you overheat. But the thermostat, hoses, cap, etc. Just check on em
Patriot Blue Y2K XJ. Big plans, small wallet.
http://www.jeepforum.com/forum/f22/00-xj-sport-daily-driver-build-thread-908084-new/
Smittyman is offline
post #11 of 16 Old 11-02-2009, 07:06 PM
compcrasher86
Agreed. My XJ has 150k miles worth of New England weather. Original starter has been holding up extraordinarily well. Even on cold freezing mornings it shows no sign of hesitation or drag. Starts up my Jeep with less than 3/4 a second of cranking every time! It literally sounds brand new.
Matt
compcrasher86 is offline
post #12 of 16 Old 11-02-2009, 07:07 PM
natertots
1990 XJ Cherokee
always check your engine mounts with the 4.0! The bolts shear off in the block and are a pain to get out. Also keep your grounds clean for less draw and battery strain.
Originally Posted by ancestralworm View Post
i wave at dog walkers and pink vw bugs and michelle pfeiffer look-a-likes and folks dressed like harry potter and two person bikes and pissed off squirrels and butterflys and day lilies and jump ropers and hobos with shotguns but there is no way in hell i will wave at a liberty. that's just gay.
natertots is offline
post #13 of 16 Old 11-02-2009, 07:40 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Regular fluid changes. Fluids are the "lifeblood" of your vehicle.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #14 of 16 Old 11-02-2009, 08:38 PM
Beefcake7777
make sure you dont have a dirty air filter. just buy a haynes manual for cherokee or something, they have maintenance schedules listed, also make sure to keep everything lubricated
Beefcake7777 is offline
post #15 of 16 Old 11-03-2009, 02:08 AM
corndogduff
Dont let your woman drive it.
Duff.
(broken)98 ZJ 5.9
UT Jeepcrew #13
NIGHTCREW
Maintenance/Preventative cyclone3565 XJ Cherokee Technical Forum 5 07-16-2008 01:57 PM
Maintenance wannabexj XJ Cherokee Technical Forum 6 05-26-2008 10:05 PM
Maintenance help LiBMXr1390 XJ Cherokee Technical Forum 8 02-29-2008 09:32 PM
maintenance c-manxj XJ Cherokee Technical Forum 1 09-17-2006 06:45 PM
Rust Preventative??? Sciotojeeper XJ Cherokee Technical Forum 8 02-05-2004 12:26 PM
