Quantcast best method to go 6.5in? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > best method to go 6.5in?
Old 09-15-2008, 10:31 AM   #1
blacklabel000
so ive got 4.5 OME right now, and i need some more clearance
so i was on ebay earlier and i found a set of RC 2" spacers for the front and 1.5-2" shackles for the back-should i go that rout
or pick up a set of new 6.5 coils and leafs?
the spacers and shackles are 100$ and the coils and leafs are 350+
so what do ya think?
thanks-nick
JustExpectEveryProblem
96' XJ: 6.5 RC lift, 35 MTRs,4.88s, 30/8.8 locked, tons of homebrew, blah blah blah...
A-TOWN 4X4
blacklabel000 is offline   Reply With Quote
Old 09-15-2008, 10:33 AM   #2
1offroadin4x4
I was in the same place as your are. I put in 1 3/4" pucks and 1 3/4 shackles in the rear. Worked just fine. I later upgraded to the 6" coils up front and left the pucks in. Still drives just fine, flexes good, and no vibes that I can feel. This also kept the jeep level, no more tilt to the front.
[COLOR="Yellow"][SIZE="2"][B]03 F-250 Super Duty Diesel
01 Cherokee Sport[/B][/SIZE][/COLOR]
[B]Member Of: [COLOR="Black"][SIZE="2"]Empty Pockets Offroad Club[/SIZE][/COLOR][/B]
[SIZE="2"][B]emptypocketsoffroad.org[/B][/SIZE]
[url]http://www.youtube.com/watch?v=uORO_JCaOAY&feature=related[/url]
1offroadin4x4 is offline   Reply With Quote
Old 09-15-2008, 10:39 AM   #3
freeburg
1987 MJ Comanche
go with the spacers and shackles...... what i did....
87 MJ 2.5 5spd 6.5" 34"TSL D30/8.8 4.88's
D44/9in(spool)5.13s redoing then putting back on the comanche maybe....
freeburg is offline   Reply With Quote
Old 09-15-2008, 10:44 AM   #4
JeepinRU
you might need a new drop pittman arm (considering the size of the one u have now)
and a new trackbar
JeepinRU is offline   Reply With Quote
Old 09-15-2008, 10:54 AM   #5
blacklabel000
new track bar yes but ive got the dropped arm already so i should be good there,
so offroadin you have roughly 8 up front and 6.5ish in back? hows that workin for ya because that exaclty what im lookin to do
i need room for my 36s under there
A-TOWN 4X4
Old 09-15-2008, 11:10 AM   #6
kg4kzv
1995 XJ Cherokee
I think your going to need new CAs if yours are not adjustable. Bake lines if you have not changed them out yet. How about a TCD or SYE if you don't have one of these you will SYE being the best. Ditch the drop pitman arm you will need to upgrade the steering.
I have a 6.5 Rusty's with short arms. I think this combo might be contributing to my DW as my arms are at a bad angle. So something you might look at.
Chris.
95 Cherokee SE 4.0, 5-Spd, 8.25;
6.5" Rusty's Lift, Atlas II Rims, 35x12.5x15 Wild Country,Rusty's Tube Bumper, Wilderness Rack
Rock Sliders, K&N Panel Air filter, PSC steering box,
I-ROK reinforcement kit, ORO U-TURN steering kit,Conversion Headlights/Silverstars And too much $$$
kg4kzv is offline   Reply With Quote
Old 09-15-2008, 11:15 AM   #7
freeburg
1987 MJ Comanche
6.5 is also the limit i'd run short arm's any higher get long arms
Old 09-15-2008, 11:49 AM   #8
1offroadin4x4
It's working great. Up until the other day I was running that much lift on adj. short arms w/ stock driveshafts and no SYE. Just recently put the drop brackets on, and wow, the difference is awesome. I've got 36's on mine and still get a good deal of flex. Took it for a drive on the road Sat. evening and can't complain, get some wobble around 50ish or so, but I'm on unbalanced tires and havn't had it aligned in forever cuzz it's primarily trailered everywhere it goes.
Old 09-15-2008, 02:58 PM   #9
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
Most of us running 36s or larger, or 35s for that matter, are doing so with with 5-6" of lift. A couple of guys are running less than that.
If you want that much lift, that's fine, but it's by no means needed to run 36s.
edit: I really hope you're planning some axle upgrades and a whole new rear axle to run those 36s though.
Jason West - Jeepin.com | JeepinOutfitters.com
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'09 JK, Unlimited Rubicon, RE 3.5", 35" BFG KM2s, Expedition One bumpers, T&T rockers & skids, XRC10 Comp
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline   Reply With Quote
Old 09-15-2008, 08:40 PM   #10
blacklabel000
already got that covered,hp44 up front and d60 in rear,frame being stiffened as we speak and im planning on makin my own long arms or buying the drop bracket kit...
and i can fit 36s now, id just like to be bigger, its a problem i have
i have changed brake lines and added tc drop, but i never did need a SYE so im set there for now.
so just go with the spacers and shackles? ive got most everything else covered, unless u think im missin something?let me know!
thanks a ton-nick
A-TOWN 4X4
Old 09-15-2008, 08:47 PM   #11
blacklabel000
well since we got that out of the way ive got a few questions before i start my axle swap if ya dont mind
what should i do about the locker situation? i have no money as it is and need to do somthing, now this is a trail rig only so the cheaper the better
thanks-nick
A-TOWN 4X4
Old 09-15-2008, 09:03 PM   #12
kg4kzv
1995 XJ Cherokee
thanks-nick
For a trail rig only and cheap. I can only think of one Lincoln locker.
Chris.
Old 09-15-2008, 09:10 PM   #13
robsjeepxj
For a trail rig only the cheapest(around $100 or less each) and by far the easiest way to lock it is definately to spool it. 100% traction nothing to fail. Throw a couple of them in and look out.
robsjeepxj is offline   Reply With Quote
Old 09-15-2008, 10:27 PM   #14
blacklabel000
ya ok ive heard of those, is that the way to go if i decide to take it on the road any time ever?
A-TOWN 4X4
Old 09-15-2008, 10:31 PM   #15
broncofire75
If you like your tires to last like 7000 miles on road run a spool.
If your just going to town and back a few times over a year or so then do it but otherwise get a cheap locker that will disengage when turning and such.
-1998 XJ Sport 4.0L-
-6.5" RE/Rustys/RC lift, Custom Y-link LAs, custom shackle relocation boxes, Pro Comp/RE monos-
-315/75/16 Toyo MTs on Moabs-
-Shaved 8.25 w/HD shafts/Auburn LS/4:10s, HP30 w/ Lock-right, sliders, HD track bar bracket, AA SYE, AppA TC skid, AFE intake, Magnaflow exhaust, Bored TB-
broncofire75 is offline   Reply With Quote
Glock Forum
