If your retainer on the axle is holding the coil spring, then so long as your not drooping so much as the top of the spring cleares the bottom of the bumpstop. you are fine.
A limiting strap bolts to the axle and the "frame" and will only allow so much down travel. Here is one example :
What springs do you have in it now. I know Rubicon express uses a relatively stiff and short spring for their 3.5" lift (250 lbs/inch or so) and that rustys coils are 150, so they should be a bit longer. Here is a list of compaineis and their spring rates, the same lift with less spring rate, will be a longer spring.
Coil Springs:
BDS 3" XJ coil 240lbs/inch
RE 3.5" XJ coil 241 lbs/inch
RE 4.5" XJ coil 169 lbs/inch
RE 5.5" XJ coil 185 lbs/inch
RE 4.5" ZJ coils are 240 lb/in. give 5.5" ish of lift on an XJ ???
Rustys 3" XJ standard coil 150 lbs/inch
Rustys 3" XJ Heavy Duty coil 180 lbs/inch
Rustsy 4.5" XJ coil 150 lbs/inch
Rustsy 6.5" XJ coil 150 lbs/inch
Rustys 9" XJ coil 180 lbs/inch
OME 930 XJ coil 160 lbs/inch ~2"
OME 934 ZJ coil 180 lbs/inch
Old Man Emu coil springs (A)= Driver side (B)= Passenger side
DPGXJ5 DPG Trailgunner 5" coils = 198lbs/in.
Rockkrawler 6.5" are 165 lbs/in
Rancho 3" coils, at least the old coils give about 2 1/4" of lift on an XJ and have a very high 235 lb/in rate.
Sky Jacker 3" ZJ coils 218 lbs/in ~4" on a XJ
OEM is supposedly 147 lb/in rate.
OEM ZJ with 4.0 is supposedly 190 lb/in rate front and rear.
Tera 4" TJ coils give 4.5" of lift on an XJ and have a 200 lb/in rate , 20.25" tall unloaded
Tera 3" TJ coils give 3.5" of lift on an XJ and have a 170 lb/in rate
