Best and correct method to reset ECM?
| 3/8" Amsteel Blue Winchline Available in Blue, Green, | Brand new! XJ Rear DIY Bumper from JcrOffroad! | Spartan Lockers FREE SHIPPING Excellent Prices |
#1 | |
I've read disconnect battery cables and touch for 10 minutes, disconnect neg cable and turn key on/off 3 times and disconnect battery cables and leave lights on for 10 minutes.
Which one or better method? Or do they all work equally well? mm
[COLOR=Navy]2001 Cherokee Sport- Patriot Blue 4.0L Auto 235x75x15 Cross Terrains w/Grizzly rims K&N FIPK |
#2 |
Just leaving the battery disconnected for about 30 minutes clears all codes just fine (assuming the faults that were present beforehand are fixed).
AZ-Jeff 1992 XJ 2" lift -- RIP 2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links. |
#3 |
Go Jeepin
This very simple procedure will erase the 1996-2001 “Adaptive Memory” stored inside the PCM and allow a new “Adaptive Memory” to be developed.
After performing this procedure the 1996-2001 PCM will re-learn and store into Adaptive Memory your engines performance characteristics. Please perform these steps exactly as they are written, in the order they are written. This will cause the adaptive memory in the PCM to be erased and cause the PCM to go into Fast Learn Mode adaptive mode. Disconnect the POSITIVE battery Terminal and touch it to ground ( not the battery negative terminal ) for 30 seconds. The engine block or the A/C compressor pump will work as a ground. (This is to discharge the PCM capacitors, which maintain the Adaptive Memory). Reconnect the Battery Cable Turn Ignition Switch to the “On” position but DO NOT start the engine Turn Headlight “On” Turn Headlights “Off” Turn Ignition Key “Off” The PCM Adaptive memory has now been flashed, or erased from the PCM. When you start the engine it will be running off a set of pre-programmed tables that come with the PCM from the factory. When you get the engine up to operating temperature the PCM will start to collect data for the “Adaptive Memory”. The PCM will collect data for Adaptive Memory for the first 50 Warm-up Cycles.
. FOR SALE: Wide Track CJ-7 Dana 44 rear axle. PM me for details A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases. Last edited by CJ7-Tim; 06-15-2009 at 02:58 PM.. |
#4 |
Tim,
Excellent info! Did you happen to get the years this procedure covers? Wm |
#5 |
Go Jeepin
I know this works on 1996+ OBD-II PCMs. I have never owned an older Cherokee so I don't know exactly how far back this works. I would guess that it is only for the OBD-II systems.
everything you have. The course of history shows that as a Government grows, Liberty decreases. |
#6 |
Update on ECM reset
My check engine light is on now, is this because the thing is in leanring mode?
mm
#7 |
my jeep has the confused prerunner syndrome....4.5" in the rear and 2" in the front. Purple Jeep Club Member # 1 |
#8 |
that same procedure worked for my 91' cherokee..dunno about older cherks tho.
Dunno why your check engine light went off when you reset the comp, did you have a check engine light before cuz it should have cleared? Too bad you cant get codes read for free anymore :/. or maybe your state dosent have that law.. |
#9 |
Ground
WHat do you mean specifically when you say to touch the posisitve terminal to "ground".
#10 |
-1998 Cherokee 4.0L, 4wd Adj. track bar, 3''/2.5 aal lift Rusty's .75 shackles Wrangler Rubicon jk take-offs, 99+ Intake Manifold swap Banks Torque header, Flow master 40 delta Rusty's 2.5 exhaust pipe Power Aid TBS, and t-case drop- |
#11 |
#12 | |
I had a O2 sensor CEL (flash code 21). I replaced the O2 sensor, removed the battery cables for about 15 minutes, and started the Jeep, just to test. The CEL remained. I did the exact method Tim outlined, and the code cleared, and in 500 miles hasn't come back, because with the new sensor it never re-tripped. For some, it seems that removing the battery cables works, I'm curious though if they've done this, or they're putting out bad information. If you've got decent condition grounding straps, simply removing both cables from the battery, and holding them together will work. The key on & one cycle of the light switch. I have a newish 2AWG cable from my block to my negative battery post though... Merry Christmas all...
You My Boy Blue! | Gutter Mount Roof Rack Brackets | 17" Steel Wheels | Stock Bumper D Rings | Clutch Master & Slave | PDC: you already have a Relay Box JEEP FIEND CLUB snowboarding |
#13 |
Tim's method does not work on my '95 Sport with the new pcm in. however, if I put the old pcm back in and run that method again, it will run ok.
I've even tried the neg cable to pos terminal for 5 minutes trick, but no bueno either. |
#14 |
tag
tag
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
