best (brightest) offroad lights - JeepForum.com
post #1 of 17 Old 11-27-2004, 01:11 PM Thread Starter
willisb
what do you guys recommend? i want the most light. a lot of people seem to go with the hella 500s but they are only 55watts, does this matter,thats no more than the headlights. how much do they really put out. i dont want to spend the $$$ on KCs. iam also looking at the procomp 130watts,but will they fit on the small space the stock xj bumper has? are they really that much brighter? i do a lot of night beach and trail riding.
willisb is offline
post #2 of 17 Old 11-27-2004, 01:36 PM
GottaBeJeep
I am a real big fan of the IPF 968 lights. They are similar in size/shape of the Hella 500's. They are only 55W, but the output is incredible. They completely drown out my Silverstars and the Hella 550's I have. Nice bright white light compared to most others.
...Off Road Armor that's "Tough as Scales"
GottaBeJeep is offline
post #3 of 17 Old 11-27-2004, 02:43 PM
madrabbitt
madrabbitt's Avatar
best and brightest?
My friend who runs baja, has at minimum 3 Hella rallye 4000 HID, lights, the middle is a pencil beam, the outer two are eurobeam.
Of course, i think about $2100 for lights is a little more then you're willing to pay.
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
post #4 of 17 Old 11-27-2004, 03:01 PM Thread Starter
willisb
hid would be nice,but if i did that it would be my headlights. iam looking for a nice set under 180-200.
willisb is offline
post #5 of 17 Old 11-27-2004, 03:30 PM
madrabbitt
madrabbitt's Avatar
Can you see i'm a big fan of hella 500s?
Top picture is my current jeep. I've actually taken them off, and i'm looking for a grille guard to mount the lower ones on. The bottom picture is my older jeep, it had a setup that took years to perfect.
The outer two had drivnig pattern with 85 watt lights with a slightly bluish tint. The inner two had fog pattern with amber lenses. The two sets complimented each other well off-road. I paid less then $120 for both sets, plus bulbs.
post #6 of 17 Old 11-28-2004, 10:22 AM
MSHarnett
Broke Bogger
MSHarnett's Avatar
I'd say the 2g HID lights would do it, haha. My lights aren't cheap, but I'll tell ya, they put the Hella's to shame. They are the IPF 900 series, its a 130W bulb with a spot and wide beam lense. The only lights I've seen better are the Light Force Lights. They are pretty big though, but the cool thing is, you can adjust the beam, just light a Mag Light.
Matt
MSHarnett is offline
post #7 of 17 Old 11-28-2004, 02:09 PM Thread Starter
willisb
what about the procomp 130w,are they good ? the ipf 900 s look nice i might just have to go with those if its worth it. i just want the most light without going broke.
willisb is offline
post #8 of 17 Old 11-28-2004, 05:39 PM
CODE
MS Harnett, can I ask what you paid for you lights? Is it just the two of them and they are enough? I'm looking into lighting next. First my headlights are being replaced, then the Trail Lights are going on. Just pricing things out, etc. Do you find you have enough coverage with your setup?
Many thanks!
DaveH.
CODE is offline
post #9 of 17 Old 11-28-2004, 05:47 PM
xxxflhrci
xxxflhrci's Avatar
Off-road lights?..............You can get a pair of utility lights at Tractor Supply for about 9 bucks. They have a rubber housing. Take out the bulbs and replace them with Wagner non-fluted 100 watt bulbs. They are also about 9 bucks at Tractor supply. I run the bulbs in the spotlights on one of my Harleys. They are blinding at night. BTW, they are not DOT. If you want, you can also get 150 bulbs. They are Wagner 4049.
xxxflhrci is offline
post #10 of 17 Old 11-28-2004, 05:55 PM
ckcooper
Bright Lights
I have not used them, but I hear that the Lightforce lights are outstanding. They are also very tough and do not weigh very much due to a polycarbonate lens and housing. You can get them with up to a 9.5 inch lens and several colored covers to snap on. Try www.offroadlights.com or www.jeepline.com...
CK
ckcooper is offline
post #11 of 17 Old 11-28-2004, 05:58 PM
MSHarnett
Broke Bogger
MSHarnett's Avatar
CODE, the pair was 200 bucks. I was looking at my 4X4 shop's website and it looks like they stopped selling the 900. Now they a 900SR or something, which is a less wattage bulb. They aint cheap, but they really do blow away the cheapo lights. These are deffinatly high quality. Its not the bulb, its the lense that counts. I've bought the cheaper lights, and even with 130 watt bulbs, they don't compaire.
The 900s are great for long range pencil beams as well as a wide angle flood type light. I have since added 5 walmart cheapo lights. Well at 5 they do light it up quite a bit, but thats 275 watts pionted in at about 45 degrees around the front. If I could do it over, I would either get the IPFs again, or the huge Light Force ones I was talking about before.
Enough babaling
Matt
post #12 of 17 Old 11-28-2004, 07:14 PM
98SportDrvr
98SportDrvr's Avatar
i am running procomp 130w's on my custom bumper and damn those are bright. plus i have some procomp 55w(bulb replaced with 75w) mounted to the top of the fenders near my windshield. those are also nice. once i rewire them all up when i pick up the jeep from the house wed ill take a pic or two to show you how bright everthing is. and yes i said the jeep is sitting at the house, a week or so ago i was being an idiot on a offroadin adventure with some people and flooded the engine. no its not hydrolocked. i blew out my distributor cap, rotor, distribution wiring and coil. 300 bux later its running again. its idling rough as hell till i take the tb apart and clean it and throw some seafoam to clean the gunk out.
used to have my project jeep.... had to sell her and now i just dream of the future.
98SportDrvr is offline
post #13 of 17 Old 11-30-2004, 04:18 AM Thread Starter
willisb
i went ahead and brought a set of the black 150w kc daylighters. i found them new for 97$ shipped. seem like a good deal to me. i cant wait to try them out.
willisb is offline
post #14 of 17 Old 11-30-2004, 11:15 AM
MSHarnett
Broke Bogger
MSHarnett's Avatar
If I were you, I'd keep a spare bulb at hand. The higher the wattage, the shorter they lost. Just a heads up
Matt
post #15 of 17 Old 11-30-2004, 01:27 PM Thread Starter
willisb
will do. thanks
willisb is offline
Offroad lights Help tsuXJFreak XJ Cherokee Technical Forum 7 10-23-2009 10:17 AM
Who has offroad lights and where did you put them?? will_coop XJ Cherokee Technical Forum 24 12-25-2008 09:39 PM
Want to set up my offroad lights... Hackmeister XJ Cherokee Technical Forum 2 06-06-2007 08:25 PM
smallest brightest lights??? kosta104 XJ Cherokee Technical Forum 9 03-26-2006 11:05 PM
offroad lights? fordpower XJ Cherokee Technical Forum 2 12-25-2004 10:56 PM
