Best brand fuel pump/sending unit? - JeepForum.com
post #1 of 8 Old 09-06-2011, 03:46 PM Thread Starter
georged4
1989 XJ Cherokee
So my fuel pump is definitely on its way out.. loud humming noise when on the gas and I have to give it a good prime for it to start after a few cranks. So I wanted to see where/what is the best pump to get. I think I should replace the sending unit as well.. or should I get a whole new tank? Thanks guys
georged4 is offline
post #2 of 8 Old 09-06-2011, 04:04 PM
avbcon12
Bosch
99 XJ 5spd 4.0l
00 XJ auto 4.0l
avbcon12 is offline
post #3 of 8 Old 10-02-2011, 10:14 AM Thread Starter
georged4
1989 XJ Cherokee
Thanks. Got it and installed it, works great, and quiet!
georged4 is offline
post #4 of 8 Old 10-02-2011, 06:00 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Bosch, Bosch, Bosch when it comes to fuel pumps for the XJ.
Did I mention that Bosch is the best option? With many years of experience on the 4.0, I install nothing but Bosch on the 4.0 engines.
Do NOT install an Airtex. IMHO, they have the biggest reliability issue of any of the fuel pump mfgs. Check other threads to verify this.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #5 of 8 Old 10-02-2011, 09:02 PM Thread Starter
georged4
1989 XJ Cherokee
yeah has been working great. only thing is now I seem to be getting worse gas mileage, I am definitely running rich. How does one tune this computer with out a obd port?
georged4 is offline
post #6 of 8 Old 10-03-2011, 05:15 AM
tjwalker
tjwalker's Avatar
No tuning of this computer. And no need to. Get at least three calculated gas mileage samples before coming to any conclusions. Miles driven divided by gallons consumed. That way, you'll know. Anything less is guesswork.
If you are truly running rich (verify by exhaust analysis is a good way) the map sensor and upstream oxygen sensors are in play here........
tjwalker is offline
post #7 of 8 Old 10-03-2011, 09:08 AM
mountainjock
1988 XJ Cherokee
Not to hijack this thread, but a quick question for walker- Made the mistake and installed the Airtex, it lasted 3 days. I can't find a sending unit assembly for my 88 I6. Napa has a carter pump, but I would need to enlarge the opening on the top cap that holds the pump in the unit, and the screen seems loose, like it may fall off with a good bump. Should I install the Carter pump? Somebody on this forum suggested rebuilding the pump. What would you suggest?
mountainjock is offline
post #8 of 8 Old 11-21-2012, 04:03 PM
jeepmannc
1989 XJ Cherokee
I picked up a Bosch fuel pump, # 69302, but the pump in the tank was longer by about 1 inch, in my '89 Cherokee Laredo. Could not use it. The problem turned out to be the hose connected to the pump and that fixed it (slipped it back on and tightened the clamp). But, I wouldn't mind replacing it anyway seeing as I have over 211,000 miles on it.
Anyone have an idea of what pump I have? I have read that in this model year there is an interesting mix of part manufacturers.
TIA, Marc
jeepmannc is offline
4.0 Oil Pump or Sending Unit Problems JLBIII XJ Cherokee Technical Forum 14 04-25-2010 02:44 PM
Fuel Sending Unit mfinkler XJ Cherokee Technical Forum 3 10-28-2007 10:47 AM
Fuel Pump Sending Unit - Bushing Forcus XJ Cherokee Technical Forum 13 01-09-2006 12:23 PM
sending unit/ fuel pump problem ilovjeep XJ Cherokee Technical Forum 5 10-29-2004 06:31 PM
Q's about fuel pump and sending unit ilovjeep XJ Cherokee Technical Forum 3 08-21-2004 05:37 PM
