Belt squeal after some light offroading - JeepForum.com
post #1 of 5 Old 10-18-2013, 04:41 AM Thread Starter
98jpchero
Hello, I have a 99' xj with the 4.0l which i just brought earlier this week. Went to test out the 4wd in some mud/water and ever since i've had a nasty belt squeal. Seems to only do it when the a/c clutch kicks on. I pulled the relay and it stops. Would that harm anything running with the relay out? Would some water have ruined the bearing on the a/c clutch? It also squeals sometimes when i take off from a stop light or on start up even with the relay out, but not nearly as bad. Any ideas/help would be help me out. I know a fair amount about cars, but i'm no mechanic. Thanks!
98jpchero is offline
post #2 of 5 Old 10-18-2013, 10:46 AM
Paradise XJ
1988 MJ Comanche
Have you checked and/or tightened the belt?
The belt on a Jeep 4.0 has to be very tight. Much tighter than just about any other vehicle I've ever had. Squealing belt after water (especially muddy water) is pretty indicative of a not quite tight or worn belt.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #3 of 5 Old 10-20-2013, 06:57 AM Thread Starter
98jpchero
Thanks! Ill snug up the belt a bit and see what happens.
post #4 of 5 Old 10-25-2013, 09:34 AM Thread Starter
98jpchero
Update, I snugged up the belt and inspected it and it looks good. Ended up being the a/c clutch. Ill just keep the relay out until the summer time. Wont need the a/c anytime soon here in northern illinois.
post #5 of 5 Old 10-25-2013, 09:36 AM
M35A2
1995 XJ Cherokee
Except to defrost the winders.
Volunteer, American Society of Military History. http://tankland.com/
Just got a 1989 YJ too!
M35A2 is offline
