battery wont hold charge any suggestions - JeepForum.com
post #1 of 18 Old 03-17-2006, 11:56 AM Thread Starter
swebilius75
swebilius75's Avatar
battery connections are clean, when jump started shows voltage at 14, just drove it for an hour and is dead again
swebilius75 is offline
post #2 of 18 Old 03-17-2006, 12:00 PM
xray
If the alt is charging then it most likely the battery. How old is it?
xray is offline
post #3 of 18 Old 03-17-2006, 12:03 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Have the battery load tested. If it test good, your alternator is bad.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #4 of 18 Old 03-17-2006, 12:05 PM Thread Starter
swebilius75
just bought the battery 2 months ago
post #5 of 18 Old 03-17-2006, 12:06 PM
Matt Gertsch
www.lp.org
That doesn't matter. Have it load tested.
post #6 of 18 Old 03-17-2006, 12:22 PM Thread Starter
swebilius75
I will try that once I can get a buddy to jump start me again, im glad to hear nothing about starters. Hope this isnt the start of a lot of things, going out to colorado for a last hurah in the jeeper. It has 230,000m under the hood and dont know how much longer it will love me.
post #7 of 18 Old 03-17-2006, 12:24 PM
fryed_1
Uhh... pull one of the batt cables while it's running. If it dies then the alternator is most likely dead.
'94 XJ - 8" Long arms, 9" rear, 35's
'89 Waggy
'48 Willys
fryed_1 is offline
post #8 of 18 Old 03-17-2006, 01:11 PM
91xjgawes
like fryed 1 sayd, take off one of the cables, it will tell you if you need a battery or an alternator
blue jeep club member 174
2001 xj- 2 inch bb moabs
1998 zj 5.2- 245/75's moabs
91xjgawes is offline
post #9 of 18 Old 03-17-2006, 01:14 PM Thread Starter
swebilius75
i will try once i can get a jump, kinda stuck at work for now.
post #10 of 18 Old 03-17-2006, 03:34 PM Thread Starter
swebilius75
well alternator works, im off to get it load tested.
post #11 of 18 Old 03-18-2006, 12:33 PM
youngwon22
Here's the real answer : Fill the battery up with distilled water, go to Pepboys or wherever and have it quickly chared & tested, then re installed the battery and...viola!
youngwon22 is offline
post #12 of 18 Old 03-18-2006, 01:24 PM
CODE
You do NOT want to disconnect the battery cable while it's running. The battery helps with voltage regulation. It's kindof a giant capacitor which helps the voltage remain at 14 and stable. With no battery on, your voltage will go above 14vdc. A lot of your sensors are not designed for 16-18 volts and can be damaged, particularly the computer.
Check the battery voltage when it sits there, jeep off: 12.8(ish)
Check the battery voltage when the jeep is running: 14(ish)
Check the alternator voltage (post regulator) when the jeep is running: 14(ish)
Check the alternaor voltage with battery disconnected, it is quite high... the batter pulls it down to a happy medium.
That stunt is OK on old vehicles, not anything with a computer. (unless you are OK with misc. component failiure.
DaveH.
DONE:
*98 CHEROKEE SPORT
*RE3.5 W/ EXTREAM DUTY LEAF PACKS, OME SHOCKS (4.5")
*TRXUS M/T's, 31X10.5 on 15x8 (3.25"BS?)
*IPF light housing w/ PIAA bulbs (4300kCalvin)
CODE is offline
post #13 of 18 Old 03-18-2006, 01:51 PM
anony91xj
DaveH.
Beat me to it. Don't disconnect your battery cable while the car is running.
1998 VW GTI 2.0
anony91xj is offline
post #14 of 18 Old 03-18-2006, 04:25 PM Thread Starter
swebilius75
thanks but too late, didnt seem to burn the computer up but did get a little smoke from the dash from my stereo. kinda scared to go drive. but yes I did do all the test with voltage and it did turn out to be my starter. new one is on and starts like it was new. just wish smoke didnt come out of my dash.
post #15 of 18 Old 03-19-2006, 06:56 PM
fryed_1
didn't know that. I've done it quite a few times with no problems... :shrug:
'89 Waggy
'48 Willys
fryed_1 is offline
altenator wont charge battery but somedays it does... joshh44 XJ Cherokee Technical Forum 6 07-13-2008 01:26 PM
Battery won't hold charge?? jirvin8 XJ Cherokee Technical Forum 7 04-22-2007 12:32 PM
help? Alternator tests okay but won't charge battery wvrebecca MJ Comanche Technical Forum 4 02-14-2007 10:06 AM
Batter wont hold charge, help! daciuk55 XJ Cherokee Technical Forum 4 01-16-2007 05:01 PM
Wont keep a charge! Jmila1901 XJ Cherokee Technical Forum 10 06-12-2006 11:14 PM
