Battery won't hold charge?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Battery won't hold charge??
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FS: Wranger BRIGHT License Plate LED! Just $3! Great valueTime To Save On Yukon Lockers!
Unread 04-21-2007, 07:59 PM   #1
jirvin8
I have a 1994 Jeep Cherokee, and when I bought it the battery was dead, but I could jump it off but the battery would not hold a charge, so I just went out and bought a new battery about a week ago. After I put it in, the car cranked right up with no problems, 14.4 voltage reading, everything checked out good. Well I don't have insurance on it yet so I haven't been driving it yet. I went out to crank it up last night, and the battery was totally dead, no underhood light, no nothing. I hooked it up to the jumper cables and it cranked right up. I took it for a quick spin around the neighborhood, turned it off, then cranked it up again. Everything seemed fine. I go out to start it the next morning, and the battery's dead again. I made sure that there was nothing left on the night before.
What do ya'll think the problem is. I haven't checked the wires yet, but is there anything else that could be draining the battery?
jirvin8 is offline   Reply With Quote Quick reply to this message
Unread 04-21-2007, 08:15 PM   #2
Jeff in PA
Two ways to deal with that.
1) "mickey mouse" it with a battery disconnect that you unhook every time you shut it off.
2) Find the draining "short".
Fully charge the battery and get a test light.
http://mypage.direct.ca/k/kdomries/testlight.html
This will allow you to figure out which circuit is still "hot" / draining power with the key off.
Good luck, I hate trouble shooting electrical problems.
Jeff in PA is offline   Reply With Quote Quick reply to this message
Unread 04-21-2007, 08:19 PM   #3
rstarch345
You've got one of the tough ones to track down. You have a high resistance short. It could be a corroded wire, bad insulation, etc. The computer and radio usually draw a small amount of current for memory retention, so that's a given.
What you are going to need is VOM, either analog or digital, that can measure DC current. The best way I know of to track the general area of problem down is;
Go to fuse panel and starting in one corner, remove a fuse. With the VOM in DC current (highest setting) put one lead on one fuse post and the other lead on the other. If the VOM pegs left or shows negative, then switch the leads. That will indicate a current draw and could be the problem circuit. Mark it, put the fuse back in and move to the next. If the meter read zero, then the circuit is OK.
Once you find the problem circuit, then it will be a tedious job of tracking all wires until you find the problem area.
Once place you can visually check is the large connector at the firewall. All of the wire go into the firewall from there. That connector has been the source of many headaches.
rstarch345 is offline   Reply With Quote Quick reply to this message
Unread 04-21-2007, 08:20 PM   #4
QwkTrip
Also, you have spent money on a brand new battery and deep cycled is at least two times now. Not good for the battery and could take 50% life off of it. It takes about 8 hours to recharge the battery to 100% state of charge. Either drive the car for a long time or disconnect the battery and slow charge it overnight.
QwkTrip is offline   Reply With Quote Quick reply to this message
Unread 04-21-2007, 08:24 PM   #5
rstarch345
Excellent point. The battery may already be ruined from holding a good charge.
Unread 04-21-2007, 10:47 PM   #6
jirvin8
Yeah that's what I figured. That suck's lol. I noticed that their is a lot of corrosion around my positive battery terminal, could that be the problem?
Unread 04-21-2007, 11:51 PM   #7
XJING
How do you have corosion on a new battery? you never cleaned the terminals when you replaced it? Yeah that could be the source of your problem..... At least one of them......
Originally Posted by FleXJ the Kid
Yes, probably, I dont know. I could but sometimes it was difficult. Just get under there and try.
XJING is offline   Reply With Quote Quick reply to this message
Unread 04-22-2007, 01:32 PM   #8
jirvin8
There is corrosion where the positive cable goes into the end of the cable not on the actual battery terminal.
