Battery will not charge - what is the issue? - JeepForum.com
post #1 of 5 Old 07-17-2010, 09:44 PM Thread Starter
B_Mabus
1994 XJ Cherokee
ok so i left the gf drive my jeep. she told me it died. went to get it confirmed it. jumped it found out it was only running on the battery, well my instinct was an alternator. replaced it charged battery up to 12.5 volts. started it volt meter was low. so i check the output of the alternator. 30 volts dc....how is that? checked the voltage at the terminals of the battery 12.3 and slowly decreasing. so i tested the terminals at the voltage regulator. 7.5 with the ignition on and running im getting 11.5. is my pcm bad? telling the alternator to charge more than it should ever do? i checked all the fuses on my power distribution block. if there's anything im over looking please help.
'89 XJ 183,xxx BLACK with olive drab....parts jeep
'90 XJ 177,xxx WHITE....sold
'90 XJ 153,xxx RED...wip
'94 XJ 145,xxx WHITE...current ride
Nothing runs like a Renix
B_Mabus is offline
post #2 of 5 Old 07-17-2010, 09:45 PM Thread Starter
B_Mabus
1994 XJ Cherokee
btw this is a 94 cherokee 4.0
B_Mabus is offline
post #3 of 5 Old 07-17-2010, 09:49 PM
BassMasterCHS
1993 XJ Cherokee
Grounds clean?
3 Inch lift, 30" BFG AT's, Walmart lights up front.
BassMasterCHS is offline
post #4 of 5 Old 07-17-2010, 09:49 PM
Holder350
1995 XJ Cherokee
Sounds like you are not getting a connection from the ALT to the battery....there are 60 amp fuses in the PDC for alternator output.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #5 of 5 Old 07-17-2010, 09:59 PM Thread Starter
B_Mabus
1994 XJ Cherokee
Ok will check both out. Thanks guys im a tech in training for Ford and im good on electrical but when it comes to my own stuff i throw the towel in too easily
B_Mabus is offline
charging system , alternator problem , battery issue
My 93 XJ battery wont charge! XJMike XJ Cherokee Technical Forum 7 03-10-2010 10:06 AM
Electrical problem: Low voltage and battery doesn't charge GreenLanternXJ XJ Cherokee Technical Forum 6 08-24-2009 08:45 PM
Battery won't hold charge?? jirvin8 XJ Cherokee Technical Forum 7 04-22-2007 12:32 PM
help? Alternator tests okay but won't charge battery wvrebecca MJ Comanche Technical Forum 4 02-14-2007 10:06 AM
battery wont hold charge any suggestions swebilius75 XJ Cherokee Technical Forum 17 03-20-2006 08:10 AM
