Battery Short - JeepForum.com
post #1 of 6 Old 09-28-2011, 08:29 AM Thread Starter
sajohnson05
Battery Short
This has happened twice now. First on Sunday and next was yesterday. My car decides not to start but when i open the drivers door it will start up. Has anyone had this issue or know why may be a problem?
Thanks
sajohnson05 is offline
post #2 of 6 Old 09-28-2011, 08:47 AM
wgirvine
1992 XJ Cherokee
So you open the door, climb in, shut the door, and it: (a) doesn't crank, or (b) cranks but doesn't start? Which is it?
Then you open the door, and it... does what? Cranks and starts?
The road goes on forever, the party never ends....
wgirvine is offline
post #3 of 6 Old 09-28-2011, 09:20 AM Thread Starter
sajohnson05
It has only happened twice but it wont crank at all. Then I open the door and it will crank and start right up. But this has only happened twice.
post #4 of 6 Old 09-28-2011, 09:39 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Be specific, when the Jeep will not start, does the starter engage and make the starting sound and but the engeine does not run, does it make a clicking noise and no starter sound at all, or does it do nothing at all ?
CJ7-Tim is offline
post #5 of 6 Old 09-28-2011, 11:53 AM Thread Starter
sajohnson05
It does nothing at all.
post #6 of 6 Old 09-28-2011, 12:09 PM
CJ7-Tim
CJ7-Tim's Avatar
Start with basic trouble shooting of the start and charge systems. Remove, clean, and firmly reconnect all the wires and cables to the battery, starter, and alternator. Look for corroded or damaged cables or connectors and replace as needed. Do the same for the grounding wires from the starter to engine block, and from the battery and engine to the Jeep's frame/body. You must remove, scrape, and clean until shiny, the cable/wire ends, and whatever they bolt to. Jeeps do not tolerate low voltage, bad connections, or poor grounds.
If you have an automatic transmission, the next time it won't start, Jiggle the shift lever back and forth while in Park or Neutral as you turn the ignition key.
Continue your trouble shooting by inspecting the Neutral Safety Switch (NSS). Check if for proper adjustment. Consider cleaning it or replacing it.
CJ7-Tim is offline
battery issue , start problems
1999 Cherokee has a Short/Battery Draw. jeepdogr XJ Cherokee Technical Forum 0 12-16-2010 09:07 PM
Short SOMEWHERE is Killing My Battery... xjarchaeologist XJ Cherokee Technical Forum 5 09-07-2009 09:56 PM
Dual Battery w/ battery in the trunk laxsmith23 XJ Cherokee Technical Forum 2 12-08-2008 04:57 PM
Dual battery with one battery in the rear. Atticus1354 XJ Cherokee Technical Forum 2 11-24-2007 11:36 PM
WON'T START! Fried battery? Big 'ol short? mchlwise XJ Cherokee Technical Forum 7 11-04-2004 09:02 AM
