Battery Gauge Drop. Check Gauges. - JeepForum.com
post #1 of 13 Old 09-12-2011, 08:35 PM Thread Starter
dkongkill
Hey all, so tonight i got in my jeep as usual and something different happened as i was driving. the check gauges light came on and my battery gauge dropped all the way down and my headlights got real dim. nothing has happened like this ever and nothing seems to be broken to make this happen to my knowledge. my battery is only a year old. what could be causing this problem? any help is greatly appreciated.
Thanks
dkongkill is offline
post #2 of 13 Old 09-12-2011, 08:40 PM
racerex1
I would have the alternator tested. That sounds like the culprit.
1999 Cherokee Classic
racerex1 is offline
post #3 of 13 Old 09-12-2011, 09:01 PM
Reptile
1991 XJ Cherokee
X2
Typical of an alternator going bad; and it will throw a code. You can run a quick test the atlernator with a digital voltmeter. Should be around 13.5-14V or so at the battery while eng running. There is a voltage differential between engine off and engine on (when atlernator is charging), if not, the alt is not charging.
There should be like a stud behind the alternator, try to move it see if power comes back. This worked temporarily for me to keep the battery somehow charged til I got around to fix it... Don't wait too long cause you'll drain the battery and shortens its life quickly, not to mention you'll get stuck somewhere.
Reptile is offline
post #4 of 13 Old 09-13-2011, 03:57 AM
oakmckinley
X2
My Alt recently died and not realizing it drove it, (just around the block) I was running on just the battery and killed that too.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #5 of 13 Old 09-13-2011, 07:10 AM
AmbuGrl
AmbuGrl's Avatar
My alternator never threw a code but did have a similiar set of problems before it died.
- HM1(SW/AW)Ret USN Dec 23,1992 to Dec 31, 2012
I drive an XJ, and all of my power windows work :)
2000 Pontiac WS6 - DD
DD (Mine) Sold - 98 XJ Moss Green
(His) - 92 YJ December 2013 YJOTM
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline
post #6 of 13 Old 09-13-2011, 09:59 AM Thread Starter
dkongkill
thanks for the help guys ill get my alternator tested immediately.
post #7 of 13 Old 09-15-2011, 02:43 PM Thread Starter
dkongkill
it indeed was the alternator and i replaced it immediately. the problem has been solved thanks everyone.
post #8 of 13 Old 05-13-2016, 07:59 AM
colinsmama08
hey guys so i have the same issues with my jeep now however we took the alternater to have it checked and it passed but when we put it back in it still does the same thing
colinsmama08 is offline
post #9 of 13 Old 05-13-2016, 08:20 AM
1989comanche
1989 MJ Comanche
Check to see if you have a fusible link. They go somewhere between the alternator and battery act as a fuse to protect wiring . On my jeep it goes from the alternator to relay.
Originally Posted by Jerry Bransford View Post
I dunno but from those symptoms, I'd first suspect the ignition switch and start from there. I'd especially suspect the ignition switch if you don't hear the fuel pump briefly cycle on-off when you first turn the ignition switch from off to on.
Originally Posted by Nemojj View Post
I didn't see a metal can
1989 Comanche
Mostly stock except homemade custom bumpers
1989comanche is offline
post #10 of 13 Old 05-13-2016, 09:13 AM
CCKen
CCKen's Avatar
CCKen is offline
post #11 of 13 Old 05-16-2016, 08:03 AM
colinsmama08
Update** I changed the alternator like someone said they did anyways and it works just fine now it was going bad so it passed the test at O'Reilly but that was the issue in my jeep. Thank you all for your help
post #12 of 13 Old 05-16-2016, 05:30 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
A fusible link either is good or bad.
If the gauge shows 9 volts, it is likely the alternator brushes are worn out and getting stuck. A bump in the road or knocking it around while removing it usually frees up the brushes. That is why the problem is often intermittent, and also why the alt will often test good inside the store, but continue to have issues. If gauge show 19 volts there is usually a loose/damaged wire connector issue or a faulty/damaged/corroded wire cable issue.
CJ7-Tim is offline
post #13 of 13 Old 05-17-2016, 10:27 PM
TDougsxj
I used to have this issue on a 99 xj when I was living in NC. Turns out the salt air got to the wires, on the battery. once I stripped them down, and put new terminals on It fixed the issue. Mine would spike voltage, or show none at all. Just for future reference. Nothing worse than electrical issues..
When in doubt, Throttle her out...
TDougsxj is offline
Battery Gauge and check gauges light.. once again gallaghergoff XJ Cherokee Technical Forum 10 04-16-2015 05:34 PM
Check Gauges Light - Voltage Drop tja XJ Cherokee Technical Forum 5 11-03-2009 06:30 PM
Check engine light battery goes dead/gauge under 14 amps reberosage XJ Cherokee Technical Forum 4 03-28-2009 09:52 AM
Can Check Gauges Light be caused by weak battery? kchilaka XJ Cherokee Technical Forum 3 04-22-2007 09:16 PM
Check Gauges and check battery light - 97 Jeep Grand Cheerokee Laredo darkstarpa XJ Cherokee Technical Forum 2 09-17-2006 06:24 PM
