battery draining overnight - JeepForum.com
post #1 of 7 Old 03-03-2010, 06:09 AM Thread Starter
martyn812
battery draining overnight due to power locks
hi guys
went to start the car sunday morning andthe battery was drained no volts at all so i put in new batteryand the next day it was dead again i tried the parsitec drain testing and found a 40amp fuse that works the central locking and seats whitch is the problem.
with said fuse in a clicking on and off noise can be heard under dash. when an amp meter is connected it shows a drain of 4 amps on and off all the time but when said fuse is removed the clicking stops and the battery stays charged this fuse is located in the fuse box next to the battery under the hood.
i tried removing the 2 relays under the dash that operate the locks but battery still drains also removed the fuse under the dash for the locks but no differance. could it be the control module under the dash is so how do i remove it or should i unplug and see if battery stays charged.
martyn812 is offline
post #2 of 7 Old 03-03-2010, 07:16 AM
3xratedxj
Have you had your alternator tested? I had a somewhat similar problem and turned out to be a diode went bad in the alt. and whenever I shut my jeep off it would eat my battery.
JEEP: The dirtiest of the four-letter words
3xratedxj is offline
post #3 of 7 Old 03-03-2010, 07:29 AM Thread Starter
martyn812
thanks have had alernator and battery tested its got to be a drain would like to know whate the under hood fuses are for book is crap wrong boxes shown mine has relays the small fuses then large fuses
post #4 of 7 Old 03-03-2010, 10:34 AM Thread Starter
martyn812
someone must know about fuses and electrics on these
post #5 of 7 Old 03-04-2010, 05:59 AM Thread Starter
martyn812
left overnight with fuse out and battery stayed charged re fitted fuse clocking starts removed both door relays still clicking note this fuse also works power seats but they work fine could it be the module itsel if so where is so i can pull plug and see if power drain stops
post #6 of 7 Old 03-04-2010, 06:12 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I think if you spent a smidge more time on punctuation and spelling that you may get more responses. Just a thought.
cruiser54 is offline
post #7 of 7 Old 03-04-2010, 06:30 AM Thread Starter
martyn812
sorry about that have edited first post to try and make some sense
Battery Draining Over 2 Days Weston3220 XJ Cherokee Technical Forum 6 01-30-2010 07:00 AM
94 battery draining GOKUSXJ XJ Cherokee Technical Forum 15 12-24-2009 07:46 AM
Battery keeps draining SoloCamo XJ Cherokee Technical Forum 10 08-23-2007 08:29 AM
Battery keeps draining rweso 89xj XJ Cherokee Technical Forum 5 09-01-2006 12:46 AM
New Battery, but still dying overnight cam-shaft XJ Cherokee Technical Forum 5 06-23-2005 09:37 AM
