Ball Joint Replacement Cost? - JeepForum.com
post #1 of 15 Old 03-09-2007, 09:47 AM Thread Starter
Sciotojeeper
Any idea what I could expect a ball joint replacement to cost? How about a U-joint?
Sciotojeeper is offline
post #2 of 15 Old 03-09-2007, 10:22 AM
crumb
If you are talking about the front axle shaft U-joints... i just did mine and it cost 19 bucks per joint. I did it myself with a BFH. It isnt hard. If you get a press it doesnt take long at all to do. I was just too lazy to get a press... er too cheap. One or the other.
I dont know how much to get it done at a shop but if you have some basic tools and some time you can save some money, even if you have to buy the press(like 50 bucks or so I think). I think you can also use the press to remove and install the balljoints.
My
1999 Cherokee Sport
4.5" RE Superflex Lift
crumb is offline
post #3 of 15 Old 03-09-2007, 01:17 PM
IntrepidXJ
IntrepidXJ's Avatar
$80 for spicer ball joints if you do the work yourself.....i've done many sets
Randy Langstraat
IntrepidXJ is offline
post #4 of 15 Old 03-09-2007, 02:48 PM
SID297
What's everyone's favorite band of ball joints? I just had all four replaced with Moog greaseable ones.
SID297 is offline
post #5 of 15 Old 03-09-2007, 03:02 PM
IntrepidXJ
IntrepidXJ's Avatar
i use spicer because they are good and cheaper (since i replace them yearly)
Randy Langstraat
post #6 of 15 Old 03-09-2007, 07:27 PM
AZ Jeff
2014 JK Wrangler
Moog is a fine reputable brand of chassis components.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #7 of 15 Old 04-06-2011, 09:11 AM
greenlawnjeeper
I know this is an old post but FWIW, my mechanic wants $600 for both sides. $75 apiece for the BJ and $300 labor. He said during a morning annual inspection that my driver side is bad but the PS is OK.
'96 Cherokee Country, Magnaflow cat and Borla exhaust, Hella 550's, Up Country suspension, Michelin MS 2's in 235x15 and Edelbrock IAS shocks. 91K orig. miles - the wife uses it ('cept when I borrow it to go huntin').
greenlawnjeeper is offline
post #8 of 15 Old 04-06-2011, 11:16 AM
Ben
They usually come in upper/lower pairs. Crown is $50 a pair.
$300 labor for a mechanic to do both sides, can't argue with that.
Ben is offline
post #9 of 15 Old 04-06-2011, 12:11 PM
mhall02
I was quoted around $600 as well, did the Moogs with my father-in-law last Jan. Rented a press from Autozone and it took roughly 6-8 hours total, for all 4. First time either of us had done ball joints, so a little bit of a learning curve, and it took more brute force than the typical Jeep repairs I had done (water pump, brakes, radiator, sensors, etc), but they popped in and out. Kind of suprised a 2000 would fail the safety inspection for these. I drive 98% highway/city driving and grease all fittings 3-4 times a year, but shouldn't have to do them again for a long time.
Here is the how-to video that I found helpful:
Patriot Blue
2000 Sport 4X4 4.0 inline six, AW-4 Automatic, stock
Original Owner 308,000 miles
mhall02 is offline
post #10 of 15 Old 04-06-2011, 12:12 PM
theducksguts
Spicer or Moog as mentioned above are both quality parts.
I highly recommend not paying a shop to do this fix.
Check out my
theducksguts is offline
post #11 of 15 Old 04-06-2011, 02:36 PM
Millermagic
http://www.youtube.com/watch?v=a3jjPouRdFw
http://www.youtube.com/watch?v=UYcqNAhk-co
My old car has visible play in the ball joints (jack it up and you could wiggle the wheel up and down) and it passed NYS inspection! Guess it's a how-concerned-is-the-shop thing?
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #12 of 15 Old 04-07-2011, 09:16 AM
greenlawnjeeper
Funny thing, my shop said he couldn't fail me on a NYS inspection with bad ball joints? How's that? Granted, I had very little play (I know you want zero play) but what about those that are ready to pop out? Having a wheel come off wouldn't be much fun. On another note (and I haven't searched topics yet), I notice some are advertised as "adjustable" to give you more camber or caster - are they necessary? I don't have a lift and the tires are 235's - if that matters.
post #13 of 15 Old 04-07-2011, 05:01 PM
ExpressoNate
1997 XJ Cherokee
NO! It will drive your alignment guy insane, and your wallet will bleed! DO NOT BUY THEM! They are adjusted by "guessing" on where to set it, installing it, hooking it up, and seeing where it's at. If it's off, u do the entire job again. Dont do it! Do you want to pay the labor for this? No... So, just have it done with a standard one.
21, Recently returned from Iraq and Kuwait.
Crashing sucks!
Save money by using
. Click my referral link to save up to 40% off retail cost!
ExpressoNate is offline
post #14 of 15 Old 04-09-2011, 07:49 AM
greenlawnjeeper
Thanks - sounds good to me.
post #15 of 15 Old 10-03-2014, 09:24 PM
DEEPSEADAMAGER
Deepsea damager
[QUOTE=ExpressoNate;11326455]NO! It will drive your alignment guy insane, and your wallet will bleed! DO NOT BUY THEM! They are adjusted by "guessing" on where to set it, installing it, hooking it up, and seeing where it's at. If it's off, u do the entire job again. Dont do it! Do you want to pay the labor for this? No... So, just have it done with a standard one.[/QU
It's funny you said that! I just took my jeep in for an alignment and the Goodyear rep tried to tell me that I needed to get the adjustable ball joints, I think that he assumed I had no mech skills! Naturally I thought he was an idiot , he also tried selling me a three year warranty for the alignment at twice the cost, to do nothing different! What ever tools are tools some you use some go home at night and sleep just like you and I!
DEEPSEADAMAGER is offline
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
ball joint and u joint replacement xGArfx XJ Cherokee Technical Forum 5 08-02-2009 06:25 PM
ball joint replacement` Jayhawk077 XJ Cherokee Technical Forum 2 05-04-2006 07:16 PM
Ball Joint Replacement BolderKeith XJ Cherokee Technical Forum 3 05-02-2006 06:57 AM
ball joint replacement JRyan XJ Cherokee Technical Forum 2 10-16-2005 08:29 AM
Ball Joint Replacement..... TampaXJ XJ Cherokee Technical Forum 4 12-23-2003 08:16 PM
