Ball Joint replacement on Cherokee - JeepForum.com
post #1 of 14 Old 01-05-2006, 02:32 PM Thread Starter
Domski
Hi,
I'm a newbie on your site, enquiring for a friend of mine who has a 4.0 Cherokee, he needs to replace the upper & lower balljoints. Could somebody please say what is involved & how easy the job is?, or a link to a 'how to' guide?
many thanks,
Domski
Domski is offline
post #2 of 14 Old 01-05-2006, 02:38 PM
conrasm
conrasm's Avatar
A ball joint press would be beneficial. It's been a while, but I remember some mention of which brand some of the guys on here liked. Might not be bad to have some post reguarding this topic again. I know autozone rents a ball joint press, but I think the quality was a little poor and it had a tendency to bend....and I think the AmPro kit that Advance sells is not the best quality either. Hopefully someone else can give some advice on the tools.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #3 of 14 Old 01-05-2006, 02:47 PM
Tazjig
Tazjig's Avatar
i would definately invest in a tool, either rent one or buy it, it makes life so much easier, ball joints on xj's aren't hard, the uppers are just a little tricky to get at.
1988 YJ Project, Stock spring (soa), dana 44 front axle, 12 bolt rear axle, turbo 350, NP205.
1988 XJ, Rusty's 6.5" lift, Custom long arms, 33's, Custom bumpers, Custom Rocker/Rock rails, SYE, Ford 8.8 - SOLD
2000 XJ, 31's with 2" lift - SOLD
1990 240sx (SR20) - SOLD
Tazjig is offline
post #4 of 14 Old 01-05-2006, 02:47 PM
AZ Jeff
2014 JK Wrangler
Go here: http://www.madxj.com/MADXJ/technical/TECHNICAL.htm
Look for the link called "Installing adjustable ball joints". The method is the same for installing regular or adjustable types, and this page shows in great detail how it's done.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #5 of 14 Old 01-05-2006, 03:13 PM Thread Starter
Domski
Cheers M8, just the kind of thing we were looking for, we are thinking of shipping some over from 'MAKO SERVICE' in the US (we're in the UK), do you know what the quality of their parts are like??
Thanks
Domski is offline
post #6 of 14 Old 08-13-2014, 01:42 PM
rjlanam
I try to search this forum but there a lot of links to madxj.com which seems to longer exist! Having a hard time not starting new threads for issues like this that threads already exist for!
rjlanam is offline
post #7 of 14 Old 08-15-2014, 06:40 AM
Kaboom22
Ball joints XJ
Try youtube videos. Make sure you get an alignment after you complete Ball joints install. Probably all day job. Be patient!
Good luck
Kaboom22 is offline
post #8 of 14 Old 08-15-2014, 08:50 AM
mhall02
Yep, I used the youtube videos as well. It took about 7-8 hours to do all 4, they are a pain to get out and everything has to be lined up perfectly when pressing them back in or they will not go. Popping them out, may want to PB blast them a few days before, as it is a workout.
Patriot Blue
2000 Sport 4X4 4.0 inline six, AW-4 Automatic, stock
Original Owner 308,000 miles
mhall02 is offline
post #9 of 14 Old 08-15-2014, 09:08 AM
calvin196
This chick made a good video I found on youtube.
https://www.youtube.com/watch?v=1sH-vAGV2qM
calvin196 is offline
post #10 of 14 Old 08-15-2014, 09:33 AM
Millermagic
I did mine in about 8 hours.
It was easier than on other vehicles. But the axle was in the back of my Jeep when I was doing the ball joints. The hard part was keeping the axle from flopping around when I was really yarning on the breaker bar and press.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #11 of 14 Old 08-15-2014, 10:16 AM
accorn
1989 XJ Cherokee
If you rent a tool, the parts store I went to had a second kit for 4wd, it basically is just more press cups. They really came in handy. Also I found you can put an impact gun on the mega c clamp once you get them started in straight. It really cut down on the removal and install time! Took me about 3 hours to do 2 the first time I did it. Pretty sure doing it again would be less than an hour per ball joint.
One other note, make sure the side you are doing is as high in the air as you can get it! Cuts down on how much oil gets into the axle shaft and later bleeds out onto your parking spot!
I am currently looking to do it again, this time with beefier ball joints.
accorn is offline
post #12 of 14 Old 08-15-2014, 12:40 PM
skyway0018746
Definitely get as many cups as you can I used almost all of them haha. Harbor freight has a full set . Had to use a breaker bar and a cheater bar to break them free.
7" long arm lift, HNT sye , herculined inside, bush wacker fender flares now geared and locked !!!
62 mm bored throttle body's fs - pm
skyway0018746 is offline
post #13 of 14 Old 08-15-2014, 01:11 PM
RLE
RLE's Avatar
Installation is much easier if you put your ball joints in the freezer the night before.
RLE is offline
post #14 of 14 Old 08-15-2014, 03:26 PM
skyway0018746
With a splined ball joint it won't help much . Better off greasing it.
ball joint replacement xjpete XJ Cherokee Technical Forum 30 01-25-2010 01:45 PM
ball joint and u joint replacement xGArfx XJ Cherokee Technical Forum 5 08-02-2009 06:25 PM
ball joint replacement` Jayhawk077 XJ Cherokee Technical Forum 2 05-04-2006 07:16 PM
Ball Joint Replacement BolderKeith XJ Cherokee Technical Forum 3 05-02-2006 06:57 AM
ball joint replacement JRyan XJ Cherokee Technical Forum 2 10-16-2005 08:29 AM
