Badly worn u joint - JeepForum.com
post #1 of 4 Old 02-13-2016, 06:36 PM Thread Starter
StreckXJ
2009 WK
Question Badly worn u joint
I developed some driveline noises that were easily tracked to a bad u joint at the front of the rear drive axle. The attached picture is what I found. The cracked leg was the obvious fault when still assembled but after pulling it, I found two legs bdly worn out of round.
I have not seen this before and want to ask if this may a symptom of something failing. Speicer 1310 greaseless are replacing both u joints in the driveshaft.
Daniel
2009 WK Laredo QTII
Formerly: 2001 XJ, 200k+ miles.
StreckXJ is offline
post #2 of 4 Old 02-13-2016, 06:53 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
That only shows is that the u-joint has been failed for a long time.
CJ7-Tim is offline
post #3 of 4 Old 02-13-2016, 08:49 PM
LAF1269
Looks like a symptom of poor maintenance......
LAF1269 is offline
post #4 of 4 Old 02-14-2016, 06:50 AM Thread Starter
StreckXJ
2009 WK
I've had this XJ for couple years and am trying to fix the neglected maintenance as a I can or need to.
StreckXJ is offline
