Bad misfire 4.0 - JeepForum.com
post #1 of 8 Old 11-19-2013, 03:50 PM Thread Starter
mikehenya
Bad misfire 4.0
Just got a 2000 Cherokee w/ 4.0 , it made it 90 miles home but missed constantly. Ticking seems a little louder than normal. When I got home I changed plugs, new TPS and new IAC. It is running better, but I am constantly getting a "Cylinder 6 misfire. I did an oil flush and am currently running some Techron through it but the miss is still there. Fuel pressure is 45.
I have been driving it locally as much as I can, misfires all the time but also has 2 other symptoms:
It is slow to return to a normal idle
After driving for a little while it starts acting like it is hitting the rev limiter at bout 26-2800rpm's. I have seen these symptoms all over the net, but no solid resolution.
Any thought? Thanks!
mikehenya is offline
post #2 of 8 Old 11-19-2013, 03:55 PM
copmedic309
1995 XJ Cherokee
Try changing your coil pack and your CPS. See if that helps.
Ry.
Rather be tried by 12, than carried by 6.
copmedic309 is offline
post #3 of 8 Old 11-19-2013, 06:52 PM Thread Starter
mikehenya
From what I have been reading, the 3 coil rail, it will miss fire on 2 cylinders? Not sure if that is true though. I guess I will try CPS next...ugghh
post #4 of 8 Old 11-20-2013, 07:39 PM
Kalali
These symptoms do not match a bad coil pack or faulty cps. Aside from the misfire code other symptoms are more like a bad tps.
Kalali is offline
post #5 of 8 Old 11-20-2013, 08:10 PM Thread Starter
mikehenya
I changed the TPS right before posting. Anything else I should look at?
post #6 of 8 Old 11-24-2013, 07:11 PM Thread Starter
mikehenya
Anyone?
post #7 of 8 Old 11-24-2013, 08:01 PM
bigbill888
pull #6 plug and see what ya got going on.
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #8 of 8 Old 11-24-2013, 08:10 PM Thread Starter
mikehenya
Originally Posted by mikehenya View Post
When I got home I changed plugs, new TPS and new IAC. Thanks!
Plugs just looked normal...
