07-13-2004, 06:55 PM
#1
just got done installing my 3.5" RE full leaf packs and noticing some grinding noises coming from my tranny yoke whenever i let off the gas. not when i accelerate, just when i let off. it looks great but i want to fix this problem. also, could i use a transfercase drop kit on my tranny? i do excessive prerunning in the desert now so i need this fixed. thanks.
2001 2-door XJ prerunner
6.5" RE
33x10.5" BFG A/T KO
15x8" rockcrawlers w/3.75" bs
hannemann 6" bulge flat top fiberglass fenders
bilstein 11" travel 5150's
RE XD trackbar / frame mount
RE adj. LCA/UCA's
beard triple thick limit straps
rusty's steering box brace
truckfarm pre-runner bumper
intake / exhaust
procomp lighting
system... yada yada yada
[URL=http://www.cardomain.com/memberpage/437678/1]PICS OF MY XJ[/URL]
07-13-2004, 07:03 PM
#2
Have you checked to make sure it isn't binding? It could be the u-joint maxing out and the slip-joint grinding on the yoke...... though I'd think you'd notice that pretty quickly.
If you have a 2001 and the RE 3.5 (which probably gave you 5...) you probably should be lookint into a SYE.
'99 Jeep Cherokee - RE 3.5" SuperFlex with 32s
'06 Dodge Magnum R/T
'03 Toyota MR2 Spyder
07-13-2004, 11:11 PM
#3
I would say make sure that the as$ end is totally settled. If you are at much more than 3" than you are going to need the extra hardware mentioned.
'91 XJ Laredo
Rustys 3" Coils Frankenleef rears||DT3000 shocks||JKS Quicker DQ
Optima Red Top||Mixin' match 31x10.5x15|| Rusty's HD Trac Bar
07-14-2004, 12:18 AM
#4
btw i am in 2wd (i know you guys bash, but i actually put it to use in the desert so just lemme do my thing) so thats why i was wondering about the tranny drop, not the t-case. if i lowered the transmission crossmember would the tranny move down too, or just put space in between the tranny-crossmember and the tranny?
6.5" RE
33x10.5" BFG A/T KO
RE adj. LCA/UCA's
intake / exhaust
procomp lighting
07-14-2004, 05:31 AM
#5
lowering the tranny crossmember should have the same effect. I personally don't have any experience with them however. If they are located farther forward then the transfer case one is normally, then I would imagine you might want to go with a smaller drop since the angles would change.
07-14-2004, 09:36 AM
#6
im pretty sure its in the same place, just the 2wd tranny is longer. ive measured the distance on my buddys 4x xj and its pretty much the same, give or take .5". so i guess ill get a t-case drop then.
6.5" RE
33x10.5" BFG A/T KO
RE adj. LCA/UCA's
intake / exhaust
procomp lighting
07-14-2004, 05:33 PM
#7
Little Red Menace
If I'm not mistaken, when I was checking out teh wife's 01 2wd the trans brace was in the same spot as the 4wd. The trans brace is referred to as the TC brace, but it's the same.
The 2wd just have a longer slip yoke housing instead of the TC slip yoke housing. A trans drop should do the trick. What axle, D35C or the 8.25? Check the slip yoke where the DS meets it and look for contact patches on the ears.
07-14-2004, 09:18 PM
#8
ive got the chryco 8.25. pics...
its pulled out a little since the lift. i have 2* shims in there too. so i think ill get the tcase drop then.
6.5" RE
33x10.5" BFG A/T KO
RE adj. LCA/UCA's
intake / exhaust
procomp lighting
07-14-2004, 09:28 PM
#9
Little Red Menace
My 8.25 was binding at about 4" so that more than likely is the culprit. Check the the DS at the yoke and see if you can find any wear spots. Shouldn't be too bad, they were just grazing eachother on mine, but sounded horrible inside.
You degree shimmed the axle yet?
07-15-2004, 02:12 AM
#10
yeah 2*. should i go more?
6.5" RE
33x10.5" BFG A/T KO
RE adj. LCA/UCA's
intake / exhaust
procomp lighting
07-15-2004, 02:38 AM
#11
Little Red Menace
TC drop should take care of it.
