#16 | |
nom nom nom
You can change the bearing in the hub. But the majority of us are better off buying a new hub assembly. http://Teamcherokee.com and http://offroadoverstock.com sell them for under $100.
'93 Cherokee Sport 4.0 man. 4.5" Black Diamond/ O.M.E., JKS control arms, discos, track bar, rear D44/detroit, 35x12.5 BFGmt's,33x13.5 LTBs,AlloyUSA shafts, oba, Warn M8000 multi-mount '97 Cherokee Sport 5spd,231, white, stock '90 Cherokee Pioneer 4.0 auto, 6" homebrew long arm lift, 33x10.5 BFG MT's, etc. '87 XJ 2" lift '96 XJ stock "Personally, I've learned so much from my mistakes, I'm thinking of making some more." "Don't believe everything you think..." |
#17 |
thanks a lot guys! like i said before, i do have access to a pretty basic home made 20 ton press and i'd rather not spend the 200 bucks. is it one or two bearings per hub and what type of job is it going to be to try and press them out?
TORQUE... An Underrated Anti-Depressant. '97 Cherokee ~6.5" / 33 trxus / RK 3-link '91 Comanche stock/4.10's/ 31's |
#18 |
Man In Black
![]() Join Date: Oct 2003
Makes me wonder how many times you can get away with pressing new bearings in before the races are to worn to provide a tight joint.
Most recently I bought a set from NAPA with a lifetime warranty, so hopefully if I do detect a warn hub, I can just take them in and exchange them. I have a worn set that I am not using that I would be willing to try and press them out and see what happens.
-Marc- Sweet Pea 1998 - XJ http://www.grobe.us/Jeep - JeepForum Rules - Become a Premium Member or Vendor For Sale: (4) AR 767-5766 Wheels (used) 15x7, 5x4.5, 4.5BS - for local pickup in the Chicago-area |
#19 | |
nom nom nom
#20 | |
'92 XJ, 4.0, AW4, DakPak & ZJ Coils |
#21 |
Man In Black
Yeah, I noticed that later myself, but didn't edit my original post.
I meant worn hub and not Warn the aftermarket manufacturer that does make hubs that aren't unitized. Hopefully that will clear up any confusion for anyone. ![]()
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
