| Moto Alliance Viper Elite 8,000lb Winch Giveaway! |
| Jeep Registry | Register | FAQ | Mark Forums Read | Search Members |
LinkBack | Thread Tools |
#1 | ||
Bad Front Wheel Bearings
TORQUE... An Underrated Anti-Depressant. '97 Cherokee ~6.5" / 33 trxus / RK 3-link '91 Comanche stock/4.10's/ 31's |
#2 |
2wd have replacable bearings
4wd you gotta buy the whole hub assembly. It's a straightforward job, but might be a pita if they have never been removed before. $136 sounds about right. If you look around on the internet I have seen them for as low as $90 apiece, but I couldn't wait for the shipping.
97 xj 44 front, detroit, alloyed 60 rear, detroit, 35 spline alloyed 35" beadlocked km2's 3" midarmed more bells and whistles than you can shake a stick at |
#3 |
are they different for 97+ or are they all the same? i did some searching and it looks like some have abs which i dont want. i found this one but is this one of those things were you get what you pay for? i dont want to be doing this again in a year....
http://www.1aauto.com/1A/wheel_bearing_front/Jeep/Cherokee/1ASHF00026/417623&ovchn=OTHER&ovcpn=GoogleBase&ovcrn=&ovtac=C MP
#4 |
that's for 84-89. I have been told that they changed the design slightly in 1990-91.
Just go to an auto parts store, ask for front wheel bearings for a 97 4wd xj, if they tell you that you need to buy the whole hub assembly, then you gotta buy the whole hub assembly.
#5 |
It's a non-serviceable assembly, gotta replace it as a unit.
#6 | |
that IS what they say. if you have a press, you can press the hub apart, its a $7 timkin bearing, grease it, press it back together, and go |
#7 | |
Senior(not yet 65)Member
#8 |
how sophicated of a press are we talkin here? i replaced my u-joints and removed the hub but i havent had a chance to look at them real good since then and it was a while ago. my friend built a pretty basic 20-ton press... is it just one bearing per hub?
Thanks
#9 | |
Either our language or our culture needs to be expanded/improved so that there is a polite way to say: Stop talking now, because I am going to stop listening. 99 XJ 3" Rusty's coils DT3000 front shocks, 3" S-10 bastard back, Homemade T-case drop, recovery points front and rear. |
#10 | |
Yes, do enlighten us... ![]() |
#11 | |
trust me, everything is not what they say |
#12 |
hes right, if you know what your doin you can do it but, its pretty simple if you have the 140 just to buy the whole assembly
blue jeep club member 174 2001 xj- 2 inch bb moabs 1998 zj 5.2- 245/75's moabs |
#13 | |
Looking forward to seeing this. Cool. Last edited by EricsXJ; 10-06-2006 at 10:55 PM. |
#14 |
90 bucks
i found new wheel bearing hub assemblies for 90 bucks through my local auto parts shop...
1998 Jeep Cherokee Sport6.5" Rough Country Lift (yes I like it)33x12.50x15 BFG KM2 Mud Terrains,Woods rear D.S. Advanced Adapters SYE D30 front Chr. 8.25 rear AX15 Man Trans NP231, C-Rok steering reinforcement check it out at: http://www.cardomain.com/ride/2403681 |
#15 |
It "can" be done (or so I've read), but also a post on NAXJA claimed that trying to do this broke some shop's quite-heavy-duty press.
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| Front wheel bearings? | MotorJunkie | Cherokee Technical Forum | 11 | 09-26-2009 10:18 AM |
| front wheel bearings | allyxj | Cherokee Technical Forum | 12 | 05-07-2008 06:36 PM |
| Replace front wheel bearings | alexrule123 | Cherokee Technical Forum | 29 | 04-19-2007 05:58 PM |
| Front Wheel Bearings | XJChris98 | Cherokee Technical Forum | 6 | 01-05-2007 09:04 PM |
| front wheel bearings | GJsJEEP | Cherokee Technical Forum | 4 | 06-17-2004 12:38 AM |
The time now is 08:33 PM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
