Quantcast Bad to drive without a TCU - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Bad to drive without a TCU
Old 12-22-2007, 09:09 PM   #1
decathect
Will this do damage?
decathect is offline   Reply With Quote
Old 12-22-2007, 09:17 PM   #2
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Not as long as you row through the gears like you should.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 12-22-2007, 09:54 PM   #3
decathect
you mean manually shift them?
Old 12-22-2007, 09:59 PM   #4
1996xj
wouldnt u have to skip from 1st to 3rd, since there is no 2nd gear selection?
1996xj
3" Rough Country Lift, 3in shackles, 3 RC shocks, 31" BFG ATs, 2 KCs, Lighted Roofrack, Soft 8s, TC drop, Custom oil leak deflector.
If only i could get a set of tires to last me 10,000Miles
Originally Posted by toates89
i am just gunna drive around in 4lo on dry streets, and peel out
Originally Posted by 4.0H.O.XJ
I once got a ticket for jerking while driving it. The cop wouldnt let me use his pen to sign the ticket.
1996xj is offline   Reply With Quote
Old 12-22-2007, 10:04 PM   #5
Timo_90xj
Timo_90xj's Avatar
1990 XJ Cherokee
Yeap, you're skipping 2nd gear. But, unless you are driving a lot on heavy traffic, won't do any damage. ..and knowing the shift points of the AW4, 3rd is usually engaged at very low speeds anyways
1998 Grand Cherokee 5.9 LX, 100k miles, 1.75" BB, 32 x 11.50 BFG MT KM2s, custom- fabbed bumpers etc..
http://www.jeepforum.com/forum/f13/daily-driver-5-9-build-thread-bumpers-tube-rockers-etc-1222317/
***Under construction***
1990 XJ (4-door), 4.0 I6, AW4, NP242, PBR 42" tires, Unimog portal axles, 110" WB, full cage + uniframe completely rebuilt, front 3-link + panhard / double triangulated 4-link rear, etc...
http://www.jeepforum.com/forum/f11/hybrid-cage-build-exo-cage-internal-973910/
Timo_90xj is offline   Reply With Quote
Old 12-22-2007, 10:19 PM   #6
decathect
So it just doesn't shift? Ok thanks, good to know.
Old 12-22-2007, 10:24 PM   #7
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
If you floor it and hold the pedal down, 3rd doesn't engage until you top 80.
"'Did you ever wonder why we had to run for shelter when the promise of a brave new world unfurled beneath a clear blue sky? "
Roger Waters
Matt Gertsch is offline   Reply With Quote
Old 12-22-2007, 10:32 PM   #8
Timo_90xj
Timo_90xj's Avatar
1990 XJ Cherokee
Well, if you keep it in 1-2, it won't shift to 3rd at any speed - at least that's how it was on mine when I somehow managed to blow the +12V feed fuse of my TCU. ..and it shouldn't change from 1st (when 1-2 selected from the lever) with the TCU disconnected, because the tranny is mechanically forced to stay on 1st.
edit: of course, that's why one should use the lever to shift to 3rd from 1st if the TCU is broken/ disconnected.
Old 11-09-2009, 06:12 PM   #9
keepishop
keepishop's Avatar
1989 XJ Cherokee
If I floor it I grab 3rd around 55mph... Maybe some adjustment is needed.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap, bronco 2 carrier, rad fan switch
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline   Reply With Quote
Old 11-09-2009, 06:15 PM   #10
justanotherjpr
You sure it isn't dropping to 2nd?
justanotherjpr is offline   Reply With Quote
Old 11-09-2009, 06:58 PM   #11
keepishop
keepishop's Avatar
1989 XJ Cherokee
Oh, you guys meant floor it AT 80mph. I thought you meant hold it down off the line.
Bleed or Quit.
Glock Forum
