Bad Cat Converter - JeepForum.com
post #1 of 8 Old 01-19-2011, 02:17 PM Thread Starter
boxerdude671
1993 XJ Cherokee
Bad Cat Converter
Alright so here is the problem, whenever I start my 1994 XJ, it sounds like a bunch of rocks rolling around. The sounds goes away as I push down on the gas but comes back as soon as I let off. It also fades away as the Jeep gets hotter. Typically this is a bad converter, right?
If it is bad, can I take it off, until I get the new one? Will it sound/smell really bad? I understand it is illegal, and I don't live in CA so I don't have to pass emission tests.
I was thinking about getting a MAGNAFLOW Direct Fit converter. Any options/better options are greatly appreciated.
boxerdude671 is offline
post #2 of 8 Old 01-19-2011, 02:47 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Gently tap on the converter with a plastic hammer and see if anything sounds loose inside. You could have bad motor mounts, a bad transmission mount, or just need some new exhaust hangers.
CJ7-Tim is offline
post #3 of 8 Old 01-19-2011, 03:07 PM Thread Starter
boxerdude671
1993 XJ Cherokee
Yep, definitely the cat. The motor mounts were replaced with some beefy new ones about 50K miles ago. When I pull anything on the exhaust it is all solid. As for the transmission mounts, I don't know. But I do the when I tapped the cat a few times, it sounded like rocks. The Jeep has 'bout 220K on it, and the cat hasn't been changed that I know of.
post #4 of 8 Old 01-19-2011, 03:34 PM
pixelbend
2007 WK
I know it's bad form to suggest taking the cat out of the exhaust system and I'm not suggesting you do it, but it just reminds me of a conversation I had a couple days ago.
I was talking to my brother in law (sister's husband, big car guy), about needing to replace mine since it was getting the rocky type sound. He said, "Oh hell, I just take mine off and run a piece of pipe up in there and knock all the crap out and put it back on." Told this to my other brother in law (wife's brother this time, who is a factory line mechanic) and he said "Yeah, that's what all the guys at the shop do to theirs."
I had no idea it was so prevalent.
Pixel
2007 WK Overland
5.7L Hemi QDII - 200k+ Hemi Club #88 | Black WK Club #151
pixelbend is offline
post #5 of 8 Old 01-19-2011, 05:33 PM
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
A new CAT really isn't THAT expensive. I would take care of it, either way, sooner rather than later. When the broken up catalyst finally plugs the outlet the Jeep will run very poorly, if at all. Usually this will happen on a long camping trip with the family while towing a pop-up camper trailer down I-95.
Regards,
Michael
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline
post #6 of 8 Old 01-19-2011, 05:51 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Pop a new cat on there. If cost is an issue, you can source them for under a hundred bucks..............
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #7 of 8 Old 01-19-2011, 06:30 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
x2, just replace it. since you dont live in CA, you can get them very cheap. CA legal cats go for around $120+...
1990JEEPXJ is offline
post #8 of 8 Old 01-19-2011, 08:05 PM Thread Starter
boxerdude671
1993 XJ Cherokee
Thanks guys. I'm getting a new one for sure, I was just talking temporarily removing it, for like two..ish weeks.
cat , cat converter , converter , xj
converter xjpete XJ/MJ Cherokee Non-Technical Forum 2 07-22-2008 08:04 PM
torque converter seal leaking=new converter?? iwishihad1 XJ Cherokee Technical Forum 3 01-23-2008 06:38 PM
Cat Converter 2 in - 1 out mrnobody_01 XJ Cherokee Technical Forum 7 03-27-2007 12:32 PM
Cat-Converter XJ95mlake XJ Cherokee Technical Forum 12 05-18-2006 03:28 PM
Cat. Converter Islandroaddie96 XJ Cherokee Technical Forum 6 09-15-2003 09:56 PM
