Bad bearing? - JeepForum.com
post #1 of 3 Old 01-02-2013, 08:33 PM Thread Starter
aldersonfilm
Bad bearing?
So I started the jeep up the other day and a sort of howling/whirring noise started coming from the front of the engine. I believe it's coming from the AC unit that's driven by the belt. It's fairly loud, but it fades after about a minute of warming up.
It's been colder than usual but I'm not sure that has anything to do with it. Anybody got any thoughts on where to start?
aldersonfilm is offline
post #2 of 3 Old 01-02-2013, 08:40 PM
kstopp
1993 XJ Cherokee
Grab a long screwdriver, place it on different areas of the engine running and put your ear to it. Be careful around the fan, it will catch you and mess you up if you get too close.
kstopp is offline
post #3 of 3 Old 01-02-2013, 08:40 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Check and properly set the fan belt tension. Inspect the fan belt. Replace if necessary. As suggested look/listen for noisy bearings.
CJ7-Tim is offline
air conditioning , noise , noise whistle noise
