Backup light fuse? - JeepForum.com
post #1 of 7 Old 05-24-2011, 11:46 AM Thread Starter
sAe23
1995 XJ Cherokee
Backup light fuse?
I searched the forum but didn't find an answer...
Is there a fuse for the backup lights, or is the NSS the only point of failure short of a wiring problem (assuming BOTH bulbs havent failed at the same time!)?
I've looked at a fuse panel diagram but it doesn't list one for the backup lights.
TIA
Steve
sAe23 is offline
post #2 of 7 Old 05-24-2011, 12:27 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
If you are missing both of your backup lights, I'd suspect the neutral safety switch. Any of the other NSS symptoms like having to wiggle the shift lever to get it to turn over, or have to start in neutral?
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #3 of 7 Old 05-24-2011, 01:04 PM
93gc40
NSS can be cleaned and adjusted.. Do that before replacing it. If only 1 bulb is the issue I'd be looking for a wiring short or bad bulb or socket.
96 XJ 4.0 / 231 / 3.5" JY Lift/ 31" BFG /.....
93 VT1100 - Harley killer.
97 ZJ 4.0 / 242 / Stock
93 ZJ 4.0 / 2"BB / Wranglers / RIP-Gone but not forgotten.
If it aint dirty, it aint a JEEP, it's just a SUV.
93gc40 is offline
post #4 of 7 Old 05-24-2011, 01:28 PM
tjwalker
tjwalker's Avatar
Link to a good article on how to "refurbish" the neutral safety switch. Good pics!
http://go.jeep-xj.info/HowtoNSSrebuild.htm
tjwalker is offline
post #5 of 7 Old 05-24-2011, 02:47 PM
FleXJay
1995 XJ Cherokee
ooooorrrr when your NSS leaves you stranded in a parking lot far away from home with little to no money with no one around you can go on your smart phone, look up the connector diagram for the NSS harness, cut up a old cell fone charger for the wires, use a nail clipper to strip the harness back and jump the 2 black wires in the harness to get her runnin again!.....not that ive had to do this or anything.......
1995 XJ Sport: 4.5in Rough Country AAL, 2.2 RC SS, Discos, 31x10.50 Dakota Definity, Cragar Soft 8's, Valley Industires Rack, Hi-Lift 48". Skids, Lockers, LA's, and MT/R Kevlars to come!
FleXJay is offline
post #6 of 7 Old 05-25-2011, 12:47 AM Thread Starter
sAe23
1995 XJ Cherokee
Sooo, no fuse then?
There are no other NSS related issues...
I suppose I could jumper the harness and see if the lights come on.
sAe23 is offline
post #7 of 7 Old 05-25-2011, 02:06 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
I'm sure the back-up lights run through a fuse, and if the related wiring rubs against body sheet metal long enough it can short out and blow the fuse. I don't see the specific fuse mentioned in my panel documentation either though.
I'm inclined to agree with the other fellows however, that the NSS turns out to be the cause for lack of back-up lights more often than anything. The starter functionality runs through a second set of contacts that seems to last a bit longer before needing cleaning. An easy way to verify which is the problem would be to unplug the NSS connection at the fireway by the tranny dipstick and use a paperclip to make a temporary jumper in the harness side receptacle. If the lights come on with the jumper in place, the problem is in the NSS. If you decide to clean and service it yourself, take your time and be careful in removing since its plastic housing can be very fragile.
Connect your back-up lights test jumper as indicated here.
***Chris***
chris87xj is offline
New backup light idea! Jmila1901 XJ Cherokee Technical Forum 12 08-09-2007 10:09 PM
backup light problem heep of feces XJ Cherokee Technical Forum 6 08-06-2007 06:39 AM
Wal-mart light mod -- backup lights? UltimatE XJ Cherokee Technical Forum 5 09-14-2006 08:35 PM
Backup Light Help Needed Alan & Tanya C. XJ Cherokee Technical Forum 1 05-02-2006 01:52 PM
Backup light switch? mofinco XJ Cherokee Technical Forum 6 10-30-2003 02:43 PM
