Backspacing help - JeepForum.com
post #1 of 7 Old 03-05-2011, 12:33 AM Thread Starter
steve888
Backspacing help
I have an xj with a 3" lift stock wheels and 30x9.5x15 bfg a/t's. As of right now I am not happy with how skinny the rear end looks with stock backspacing, or lack there of. I am looking at getting cragar soft 8's, should I run a 15x8 or stick with a 15x7? Also what kind of backspacing would be appropriate to get the wider look without having to do any trimming?
steve888 is offline
post #2 of 7 Old 03-05-2011, 04:39 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
If you plan to stay with a 30x9.50 or a 31x10.50 tire the 15x7 will work great. The 15x8 will work also, but the backspacing will set the stance. I would go with 4" if you want the tires to sit farther out, 4.5" will keep them under the flares better though. with 3" of lift and 30's you shouldn't have to trim anything unless you flex it out a lot.
xjfever is offline
post #3 of 7 Old 03-05-2011, 08:27 AM
habbyguy
I agree with xjfever... 4" or so of BS sets the tires nicely out near the edge of the flares. I'm using wheels with 5.5" of BS with 1.25" spacers for an effective BS'ing of 4.25" with 31" tires, and consider the end results perfect. Here are the before and after photos (with Grizzly 15x7 wheels with 5.5" of BS - my GC Canyon wheels with my off-road tires have the same dimensions). Keep in mind that the before photos (first two) show what 5.5" of BS looks like, and the after photos (last two), what 4.25" of BS looks like with 31"x10.5" tires...
habbyguy is offline
post #4 of 7 Old 03-05-2011, 09:58 AM Thread Starter
steve888
Thanks for the help and photos that is exactly the look I am going for. Where is a good place to pick up a set of those spacers?
steve888 is offline
post #5 of 7 Old 03-11-2011, 06:56 AM
habbyguy
I don't remember - but I do recall that the lug nuts supplied didn't work on the XJ's lugs. So... I ended up having to buy both "open" lug nuts like the ones in the photos (that would hold the spacers on the hubs, since they had to fit down inside the holes in the spacers but stay below the surface of the spacer), plus I had to buy "closed" lug nuts (the tall ones that cover up the lug when installed) that fit the adapter's lugs. You will want to check the specs on the threading for the XJ and adapter lugs to avoid that particular hassle.
One more detail - if I was running a common 15x8" wheel (like the Wrangler Canyon wheel), they would stick out of the fender wells 1" more than in the photos. The backspacing determines where the BACK of the wheel ends up - then the width of the wheel determines where the FRONT of the wheel ends up.
habbyguy is offline
post #6 of 7 Old 03-12-2011, 12:33 PM Thread Starter
steve888
habbyguy, thanks I never really understood what backspacing did until now, Im gonna look at different spacer options this weekend, hopefully ill have something ordered soon.
xjfever, when I do finally decide to get new wheels i want the look that you have, what kind of backspacing/wheels are you running on your jeep?
steve888 is offline
post #7 of 7 Old 03-12-2011, 01:06 PM
cbordea
a lot of times you can buy rims with 4 inch offset as cheap as the spacers and tire shops won't freak out.
It also lets you keep a spare set of rims and tires if you want to keep a set of street tires and a set for offroading.
I didn't really shop, just a quick google search and found these..
http://www.jegs.com/i/Cragar/260/342-5712/10002/-1
88 MJ I6 4x4 Stock my hauler - Sold
98 XJ I6 4X4 Stock my son's DD
06 12V Purple Barbie Jeep my daughter's DD :-)
cbordea is offline
backspacing nfm XJ Cherokee Technical Forum 3 03-21-2008 07:20 PM
backspacing? poondeezie XJ Cherokee Technical Forum 2 12-16-2006 12:41 PM
Backspacing?? somewherre XJ Cherokee Technical Forum 4 11-22-2006 11:39 AM
rim backspacing ready to mud XJ Cherokee Technical Forum 1 10-09-2006 12:34 AM
What Backspacing....3.75 or 4.5?? Weedo XJ Cherokee Technical Forum 15 09-01-2006 08:39 PM
