Backfiring Through Intake - JeepForum.com
post #1 of 14 Old 03-23-2009, 08:45 AM Thread Starter
drewguere
drewguere's Avatar
My cherokee is making a popping noise and backfiring through the intake. It used to do this periodically, but it is now doing it a lot more often.
I looked it up and it said it could be a problem with the timing, having a lean mixture, or a vacuum leak
Has anyone else had this problem? Anyone have a solution, or something to check?
2002 GMC 2500HD 8.1L - Tow Rig
1998 Jeep Cherokee - Wheelin Rig
1988 Jeep Wrangler - In progress...
drewguere is offline
post #2 of 14 Old 03-23-2009, 09:02 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
How about a specific and detailed description of when and how your Cherokee does this trick. All the time, sometimes, only when cold, only when warm, only after ........... ? What parts, sensors, or systems have you inspected, have you tested, or have you replaced ?
When was your last full tune-up ?
CJ7-Tim is offline
post #3 of 14 Old 03-23-2009, 10:05 AM Thread Starter
drewguere
drewguere's Avatar
It used to do it rarely, usually when taking off from a stoplight or something. Now it is doing it whenever I start the jeep.
You can hear it sucking air through the intake very hard, like you can hear it over the motor when the hood is open. It will sound like its going to die, then rev up a bit, then do it again and again.
It does it warm or cold.
The jeep hasnt been driven since september 07. So of course I need a tune up, and I will get to that this weekend, but this problem was happening even when I used to drive it daily and had new plugs/wires on it.
It has a brand new crank sensor on it, and relatively new O2 sensors.
post #4 of 14 Old 03-23-2009, 10:14 AM
CJ7-Tim
CJ7-Tim's Avatar
Originally Posted by drewguere View Post
It will sound like its going to die, then rev up a bit, then do it again and again....It does it warm or cold....
Put a can of SeaFoam or Chevron Techron fuel injector cleaner into the next two gas tank fill-ups. Clean the Idle Air Controller (IAC) and throttle body. Tune up with Champion spark plugs, a new air filter, new wires, cap, and rotor.
If you get all the routine maintenance done and it still mis-behaves, test the Throttle Position Sensor and Coolant Temperature Sensor for smooth response and readings within specifications.
Cleaning the Idle Air Controller (IAC) :
Purchase sensor safe Throttle Body cleaner spray.
1. Remove the Throttle body from the intake manifold.
2. Remove the IAC with a TORX 15 driver (2 bolts)
3. Gently wiggle out the IAC from the throttle body
4. Clean the IAC with throttle body cleaner (not carburetor cleaner) Use cleaner, a rag and a toothbrush.
Be gentle; don’t twist or pull on the pintle as it is fragile and can be damaged easily
5. Also clean where the IAC seats in the throttle body with the same throttle body cleaner
6. Reinstall IAC, the Throttle body, and check idle quality.
CJ7-Tim is offline
post #5 of 14 Old 03-23-2009, 04:10 PM
CheyenneK5
also check your fuel pressure...a faulty fuel pump will cause this as it causes a lean condition
For Every One Person with a Spark of Intelligence, There are 100's with Ignition Trouble
The Comments made by this Person are in NO way meant to Offend anyone, they are the opinions of a single person and if they piss you off then sorry about your luck
CheyenneK5 is offline
post #6 of 14 Old 03-23-2009, 08:37 PM
swells
1990 XJ Cherokee
my cherokee backfired through the intake when I would start it. the battery was toast and the alt was only producing 9 or 10 volts apreantly low voltage causes this and many other problems
thanks swells
swells is offline
post #7 of 14 Old 03-24-2009, 05:55 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
I agree with CheyenneK5, fuel pressure would be one of the first tests to perform. Takes only a few minutes and a fuel pressure gauge installed on the schrader valve on the fuel rail. Compare to factory specs.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #8 of 14 Old 03-25-2009, 08:46 AM Thread Starter
drewguere
drewguere's Avatar
Where would I get a fuel pressure guage?
Would auto zone or something like that have one?
post #9 of 14 Old 03-25-2009, 09:28 AM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
Bingo. Low fuel pressure will cause backfiring thru the intake.
FP gauges can be purchased at Autozone.
88XJSport is offline
post #10 of 14 Old 04-08-2009, 11:52 AM
Camo-5
1978 FSJ Cherokee
Any luck finding out what this was? I have the EXACT same problem. I could not describe it any better myself. Mine started last summer, went away for over 6,000 miles, then came back again a couple weeks ago. I've done the following trying to figure out what it is:
New TPS
New Idle air control
New throttle body (well, I wanted a 62mm anyway)
New MAP sensor
New plugs, cap, rotor, wires, coil, battery.
I just bought a new temp sensor today so I'll try that over the weekend (need to replace thermostat anyway).
If that doesn't work, I'm going to move onto the alternator. I just replaced the battery. Not sure if it was bad, but it was 6 years old. It wouldn't hold a charge very long. Maybe it was the alternator.
Anyway, please let me know if you find out what you problem was and I will do the same!
BTW, great site! I've been visiting for years, figured this would be a good time to join in!
Camo-5 is offline
post #11 of 14 Old 04-08-2009, 02:45 PM
98CherokeeLTD
1992 XJ Cherokee
mine has had the same issue ever since I got it. But mine only does it when its damp or i go baja thru a puddle. so i think mine may be a vacuum leak..it gets really annoying when your wheelin and it starts poppin and fartin and losin power
Originally Posted by -XJguy- View Post
Damn pesky trees always jumping out into the middle of the road without looking.
98CherokeeLTD is offline
post #12 of 14 Old 08-25-2011, 07:29 AM
chadtheman
DId you end up fixing the problem. MIne is doing the same thing and is getting super annoying.
MIne started doing it while i was wheeling. SAme thing backing firing through the intake and when i jam the pedal down, it hesitiates real bad and acts like it is gonig to stall.
chadtheman is offline
post #13 of 14 Old 08-25-2011, 11:55 AM
Topgun514
1988 XJ Cherokee
Chad, sounds like a TPS, follow CJ7-Tims examples first
87 XJ pioneer-Totalled
96 XJ Sport- Sold
Now: 88 RENIX 4.0 XJ, Project Overlander
3.5" Lift, RE SF LCA's with skids, 31x10.50R15 Duratracs, ARB Roofrack, Custom Bumper, Glasspack, Bored TB, Custom seats
Topgun514 is offline
post #14 of 14 Old 02-02-2014, 11:08 PM
DallastheJeeper
anything happen with this?
|^^^^^^^^^^^^^^^\ ||__
|.......PBR BEER TRUCK.... ||""\_____\
|____________________/||__/----|
#5-06 Salvage Rebuild LJ
Metalcloak Bumper, Overline fenders and Corner guards.
3.5" Sus Lift
1'' Body lift and engine lift
#4-98 TJ Sahara RIP :(
#3-42 GPW Project. Currently on hold Sand blasted the body and it was held together by screen and bondo so new Tub needed
#2-88 Comanche Currently getting a frame off rebuild and a 4bt.
#1-1994 Power Wheels Wrangler
DallastheJeeper is offline
Backfiring Out the Intake & Power issue Guitarpicker503 XJ Cherokee Technical Forum 7 12-25-2008 08:32 AM
XJ Sputtering and backfiring through intake OCNYxj XJ Cherokee Technical Forum 6 09-07-2008 10:11 PM
Rough, low idle, Backfiring thru intake and CEL on... ripoil XJ Cherokee Technical Forum 21 11-25-2007 05:27 PM
Intake Backfiring? 88 XJ. NightbaneZ24 XJ Cherokee Technical Forum 1 03-18-2007 07:00 AM
Backfiring shierkahn XJ Cherokee Technical Forum 9 03-15-2007 11:53 AM
